05-12-2011 09:33 AM - edited 07-03-2021 08:11 PM
Hi to all,
i want to use local-eap+LDAP (microsoft AD) and i'm experiencing some issue.
First of all i'm not able to bind WLC and LDAP...if a perform a debug aaa ldap enable i get this output:
Any idea about how to solve this issue?
Ale
05-12-2011 10:33 PM
It sounds like .... invalid credentials ? :-)
Please post your LDAP config on WLC.
Is your admin username with which you're binding within the search context that you defined ? this is very important
05-13-2011 02:36 AM
simple bind=authenticated
port=389
bind username=user
user base DN=DC=company,DC=local
User Attribute=sAMAccountName
User Object Type=OID
i will chek the bind user
05-14-2011 10:20 AM
user object type=oid ?
usually in AD, it's "Person". Is there a reason for OID ?
