wlc and ssid
vadik2005
hi, all!
i try to find an answer if wlc can advertise not all ssid to the lap's. how can i setup this feature?
for example - i have 10 LAPs over the building and 5 SSID's.
i need to advertise only 3 SSID at the 1 floor and all of them at the second floor.
is it possible?
ps sorry for my bad english ))
jigsaw2026
Hi Vadik,
Yes it's possible - in version 4 you would use WLAN override. Basically in the radio config of each AP you can select WLAN override, and then check the WLANs that you want to advertise.
In version 5 you would use AP groups.
I've found this quite helpful:
http://www.cisco.com/en/US/docs/wireless/controller/4.0/configuration/guide/c40wlan.html#wp1114777
J
jigsaw2026
Hi Vadik,
J
thanks a lot!
