Hi all,
is it possible to create a VPN (or other something similar - like GRE) tunnel from any physical/logicel interface of a WLC (running OS 4.2.207.0) to a remote router? We'd like to tunnel the Usertraffic to a remote device to allow the user to access an untrusted segment and not having the VPN Tunnel in place will cause routing issues.
Thx in advance!
Cheers
Martin
