WLC firmware upgrade
Srin_G
Level 3
Level 3
Hi all,
we are running code 7.6 in foreign wlc (8510) and 7.4 in anchor wlc!
Thinking of upgrading the foreign wlc to v8.0.140 should i upgrade the anchor to the same version? what is the best practice?
Thanks for any inputs.
regards
No problem. You can have diff hardware and didd version both controllers.
Check table 19 and table 20 for matrix:
Dont forget to rate helpful posts
Sandeep Choudhary
They don't need to be on the same code but if you can then I would recommend to keep on same version(but its not a must).
Here is a matrix that show the compatibility:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-201251
Hi Sandeep,
Thanks.The anchor runs on 5508 platform! Will it make any difference?
There are plenty of matrix tables out in the document, which ones exactly references the EoIP tunnel compatibility for different versions.
please advise.
thanks mate!
cheers
