WLC Mesh issue - 1532 and existing 1142 mesh deployment - CSCvb85177 ?
paulcatchpole
I'm seeing the exact behaviour referenced in CSCvb85177 with a pair of 1532E APs attempting to stay joined to an existing mesh of LAP1142s.
WLC 8.2.170 at remote datacentre, L3 discovery required
Discovery by DNS
1x 1142 RAP [Flex-bridge]
4x 1142 MAP [Flex-bridge]
1x 1142 non-mesh [Flexconnect]
2x 1532 MAP [Flex-bridge]
The network of 1142s has been stable for a year or so, no unusual issues. I've moved the 5ghz backhaul from the indoor-only (GB) channel 44 to 40mhz 108 (indoor-outdoor) across all mesh APs. Absolutely nothing on those channels in this location, DFS detects nothing, and surveying can't hear anything.
Symptoms are that the 1532s will select a parent, DHCP, find the controller and be happy. This lasts for anywhere between 8 and 24hrs so far. At some point in that timeframe, the 1532 will report that its parent has gone down, flap a bit between 'down' and 'control' states on the backhaul radio, then reselect the same parent which it'd lost. At that point, the mesh adjacency looks correct, parent 1142 is happy, 1532 is happy as a child, keys installed and running.
Mesh adjacency from RAP:
INST-LAP1142-hall#show mesh adjacency child
 show MESH Adjacency Child
ADJ 2 Identity 84b8.02ac.ff42 MA: 8890.8d92.d8ef ver 0x20 minver 0x0 on device Dot11Radio:1 txpkts 616416 txretries 22182
Flags: CHILD BEACON
        worstDv 255 Ant 0, channel 108, biters 0, ppiters 10, fwd_state 3
        Numroutes 0, snr 0, snrUp 37 snrDown 0 linkSnr 0 blistExp 3 bliters 0
        adjustedEase 0 unadjustedEase 0 stickyEase 0 txParent 0 rxParent 0
        BGN newnham
        Vector through 84b8.02ac.ff42:
        Per antenna smoothed snr values: 0 0 0 0
        Subordinate neighbors: 84b8.02ac.ff42
        Hop-Count Extension: ON, Version: 1
Mesh adjacency from 1532MAP:
INST-CAP1532-OUTDOOR#show mesh adjacency parent
 show MESH Adjacency Parent
ADJ 4 Identity c47d.4f39.f4fe MA: c47d.4f52.d1ff ver 0x20 minver 0x20 on device Dot11Radio:1 txpkts 13684 txretries 2394
Flags: UPDATED NEIGH PARENT BEACON
        worstDv 0 Ant 0, channel 108, biters 0, ppiters 10, fwd_state 3
        Numroutes 1, snr 0, snrUp 49 snrDown 37 linkSnr 34 blistExp 3 bliters 0
        adjustedEase 6248576 unadjustedEase 6248576 stickyEase 8648576 txParent 9469 rxParent 5411
        Authentication: EAP, Encryption: AES-CCMP, Fwd-state: OPEN/CONTROL
        BGN newnham
        Vector through c47d.4f39.f4fe:
                Vector ease 1 -1, FWD: c47d.4f39.f4fe
        Per antenna smoothed snr values: 33 0 0 0
Mesh and other status on MAP:
INST-CAP1532-OUTDOOR#show mesh status
 show MESH Status
 MeshAP in state Maint
 Uplink Backbone: Virtual-Dot11Radio0,  hw Dot11Radio1
 Configured BGN: newnham, Extended mode 0
 Children: Not accept child
 No.of Children: 0
        rxNeighReq 67348 rxNeighRsp 94721 txNeighReq 58769 txNeighRsp 67348
        rxNeighRsp 588146 txNeighUpd 148618
        nextchan 0 nextant 0 downAnt 0 downChan 0 curAnts 0
        nextNeigh 1, malformedNeighPackets 0,poorNeighSnr 431
        excludedPackets 0,insufficientMemory 0, authenticationFailures 0
        Parent Changes 3, Neighbor Timeouts 4
        Authentication Failure statistics
        Child MAC                 No.Of PSK Failures
Preferred Parent 0000.0000.0000
INST-CAP1532-OUTDOOR#show capwap ip config
LWAPP Static IP Configuration
IP Address         172.20.0.105
IP netmask         255.255.255.0
Default Gateway    172.20.0.1
INST-CAP1532-OUTDOOR#show capwap client rcb
AdminState                  :  ADMIN_ENABLED
SwVer                       :  8.2.170.0
NumFilledSlots              :  2
MwarName                    :  wlc-cov-greenferret
MwarMacAddr                 :  5ee5.4fac.0000
MwarHwVer                   :  0.0.0.0
ApMode                      :  Flexconnect+Bridge
ApSubMode                   :  Not Configured
OperationState              :  DISCOVERY
CAPWAP Path MTU             :  1485
Link-Encryption (AP)        :  Disabled
Link-Encryption (MWAR)      :  Disabled
Prefer-mode                 :  IPv4
LinkAuditing                :  disabled
ApRole                      :  MeshAP
ApBackhaul                  :  802.11a
ApBackhaulChannel           :  0
ApBackhaulSlot              :  3
ApBackhaul11gEnabled        :  0
ApBackhaulTxRate            :  0
Ethernet Bridging State     :  0
Daisy Chaining State        :  Disabled
Public Safety State         :  disabled
AP Rogue Detection Mode     :  Enabled
AP Tcp MSS Adjust           :  Disabled
Predownload Status          :  None
Auto Immune Status          :  Disabled
RA Guard Status             :  Enabled
Efficient Upgrade State     :  Disabled
Efficient Upgrade Role      :  None
TFTP Server                 :  Disabled
Antenna Band Mode           :  Dual Band
Universal AP Priming mode   :  Unprimed
802.11bg(0) Radio
ADMIN  State =  ENABLE [1]
OPER   State =      UP [2]
CONFIG State =      UP [2]
HW     State =      UP [4]
  Radio Mode                : Flexconnect+Bridge
  GPR Period                : 10
  Beacon Period             : 100
  DTIM Period               : 0
  World Mode                : 1
  VoceraFix                 : 0
  Dfs peakdetect            : 0
  Fragmentation Threshold   : 2346
  Current Tx Power Level    : 3
  Current Channel           : 13
  Current Bandwidth         : 20
802.11a(1) Radio
OPER   State =      UP [2]
HW     State =      UP [4]
  GPR Period                : 10
  Beacon Period             : 100
  DTIM Period               : 0
  World Mode                : 1
  VoceraFix                 : 0
  Dfs peakdetect            : 1
  Current Tx Power Level    : 1
  Current Channel           : 108
  Current Bandwidth         : 40
However, it then tries its (recently attempted) static address, but the gateway fails to be reachable, causing it to fallback to DHCP. It never receives a DHCP response, and so sits there offline, awaiting an IP.
The issue in the bug is described as a DHCP issue, which is what it initially appears like. However, with packet capture on the wire from the RAP, it's clear that the DHCP response to the 1152MAP is being sent from the DHCP server back towards it, but never being received by the MAP. After adding a static IP to avoid this DHCP problem, the AP arps out for its gateway, and again the response from the gw is visible on the wire, but never received by the MAP.
Bridge forwarding tables on the MAP and RAP both show 0 packets for the relevant MACs.
Capture from RAP here, showing the 1532 continually trying to ARP out for its gateway:
What do we think is going on here then?
My current guess is that there's some incompatibility between the 1532 and the 1142. The referenced bug has two support cases noted, but no workaround or fix.
Any help appreciated!
Cheers, Paul
paulcatchpole
I haven't got very far with the 1532 access points still.
The two behave differently, which is somewhat odd given they have very close serial numbers and were made in the same week; same software (obviously), same bootloader, same revision, same antennas.
So far, I've flattened them properly again, by booting into rommon and deleting everything but the image from flash, then booting them off-controller and doing a capwap clear, then letting them join over the wire and reconfiguring.
Both seem sensitive to dropping off the network and getting into weird states if there's other mesh APs coming and going on the network.
One goes into a flashing green state and *sometimes* rejoins correctly. The other goes into a flashing red state, and is the source of the debug output in my first post, where it refuses to receive packets. I can't see the flashing red is a relevant output - the docs say that's 'ethernet link down' which it clearly is, as it's a Mesh AP. Anyone seen that on one of these? Video below.
I've replaced the RAP with a 3702, from the original 1142. The 3702/1532 Cisco state is an approved mesh solution in the docs. That hasn't made any difference.
I'm not understanding why the 1142 mesh works fine; any AP can be rebooted or drop off due to marginal signal and rejoin without getting into a state. These 1532 seem incredibly unreliable and flaky. Sigh.
Anyone think that power might be an issue here? They're DC powered from 48v PSUs which can supply 24w, which is only just above the requirements. I've got a pair of 120w PSUs arriving to try.
While I'm asking for help - anyone else noticed that Prime (3.9 in this case) can't pull mesh link SNR from the Controller / APs ? I get 0db and blank graphs in Prime. Looking manually on the Neighbour Details on the Controller shows the link SNR correctly. Saw one report of it being an SNMP bug, but nothing else.
Ta, PC
Somewhat talking to myself here, but it might help someone else seeing the same issue with Prime; the controller returns zeros for mesh link SNR in the mesh neighbour table via SNMP, which is presumably why Prime reports it as zero.
Odd that it hasn't been seen more often.
root@host:/home/paul# snmpwalk -v2c -c redacted 94.229.79.172 1.3.6.1.4.1.9.9.616.1.3.1.1.3
iso.3.6.1.4.1.9.9.616.1.3.1.1.3.8.204.104.138.242.240.124.14.206.11.94.224 = INTEGER: 0
iso.3.6.1.4.1.9.9.616.1.3.1.1.3.8.204.104.138.242.240.136.144.141.146.216.224 = INTEGER: 0
iso.3.6.1.4.1.9.9.616.1.3.1.1.3.8.204.104.138.242.240.136.144.141.146.218.48 = INTEGER: 0
iso.3.6.1.4.1.9.9.616.1.3.1.1.3.124.14.206.11.94.224.8.204.104.138.242.240 = INTEGER: 0
iso.3.6.1.4.1.9.9.616.1.3.1.1.3.124.14.206.11.94.224.136.144.141.146.216.224 = INTEGER: 0
iso.3.6.1.4.1.9.9.616.1.3.1.1.3.124.14.206.11.94.224.196.125.79.82.209.240 = INTEGER: 0
iso.3.6.1.4.1.9.9.616.1.3.1.1.3.136.144.141.146.216.224.8.204.104.138.242.240 = INTEGER: 0
iso.3.6.1.4.1.9.9.616.1.3.1.1.3.136.144.141.146.216.224.124.14.206.11.94.224 = INTEGER: 0
iso.3.6.1.4.1.9.9.616.1.3.1.1.3.136.144.141.146.216.224.136.144.141.146.218.48 = INTEGER: 0
iso.3.6.1.4.1.9.9.616.1.3.1.1.3.136.144.141.146.218.48.8.204.104.138.242.240 = INTEGER: 0
iso.3.6.1.4.1.9.9.616.1.3.1.1.3.136.144.141.146.218.48.136.144.141.146.216.224 = INTEGER: 0
I've connected the most flaky 1532, this morning, to a new 120w 48v PSU. Uptime before going weird has been variable; it can do 15hrs then 'crash' twice in an hour. Let's see if more power is helpful.
Cheers, PC
