WLC running config
vijay kumar
Level 2
Level 2
Hi Friens,
I want to see the running configuration of WLC as like routers and switches. But in WLC running config it is giving all the inventory, AP details and everything.
Is ther any cmd to see the configuration in commands format?
Vijay.
2 Accepted Solutions
Stephen Rodriguez
sure.
show running-config no-ap
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
You need to take a look at it... one has the config command and the other doesn't.  If your looking for the configuration, then you just need to backup the WLC as you will not be able to paste the show run-config.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
7 Replies 7
Stephen Rodriguez
sure.
HTH,
Steve
HTH,
Steve
Thanks steve.
Is this command output and the config backup through WLC GUI will be same?
regards,
Vijay
they should be pretty darn close to the same.
HTH,
Steve
HTH,
Steve
Scott
-Scott
Thanks for the reply.
If I add config command in the show run command output, will i be able to paste it in WLC?
Vijay
You can, but the order in which the config is pasted makes a difference.  That is why there is no true cut and paste method.
Scott
-Scott
That command wouldn't work for my 5508 running 7.4.110.0 code
But this did :
show run-config no-ap
Just a slight syntax issue =)
