WLC2054 and AP1231G traffic issue
Hi Guys.
One of my customer has a wlc2504 and a couple of old 1231.
On release notes of controller i read that the last support with that kind of AP is with controller release 7.0.
So we installed 7.0.235 and APs register correctly.
configured SSID are visible but when i try to join it I cannot receive ip address and if I configure a static ip on my Wireless interface, I cannot ping anything and no traffic is present on that IF.
Can anyone help on this?
Many Thanks
Cheers
Carlo
Please rate all helpful posts "The more you help the more you learn"
ali aqrabawi
Level 3
Level 3
share :
show wlan <wlan id>
show client details <client MAC> //while the client is trying to connect
debug client <client MAC> // while the client is trying to connect
Hi Ali.
Many thanks for your answer but I figured out where the issue was.. Proxy Dhcp feature was  in disabled status.
Just after activated all started to work.
Cheers.
Carlo
