WLC2500 (2504) issue
joyride_us2
Hi!
I have an issue with my WLC2504 box. After some manipulation of the box :
- I cannot reset the config : it comes back to the config I had set in
- I cannot use the Console port any longer (?)
- the only way to access the console mode I have, is through the AP 1832I console port...but the controller does not accept the administrator password. Dead!
Let's start there!
5 Replies 5
Leo Laohoo
The 2504 has a "Reset" button in front.  What happens if you press this down and apply power?
Simple : nothing!
I come back to the old config!
Benoit Loriaux
Well,
I would say you'll have to put a downtime notice.
I hope you have a backup of your config somewhere.
Step 1 plug you console cable in the WLC and make sure you are recording the session.
2 pull the plug or use the reset button
3 watch the output and once booted attempt to log in the WLC
4 if it's all crashed you will have information right there !
Have you attempted to update the code of your WLC ?
Cheers,
Ben
OK. let me try it (this is a lab, by chance !)
sorry the console port of the WLC does not work any longer....that's another challenge, especially since the reset button does not produce any effect : the controller remains on the config I sat up (can see it through the WEB interface)!
