cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
7
Respuestas
WLC2504 (8.0.133.0) and 2702i AP
desmond.liew
Hi All,
I was wondering if anyone can help me with the above issue. I just setup a WLC2504 with couple of 2702i access points. The license for the WLC2504 hasn't arrived yet so I am running on evaluation license for now. My access points are on the same VLAN as the WLC but each WLAN (SSID) I configured on a separate VLAN.
Anyway, the point is that, when I configure a WLAN and enabled Radio Policy = All. I used INSSIDER to determine whether the 5Ghz network is working. I do not see the 5Ghz network. I only see on the 2.4Ghz network.
I checked under:
  1. Wireless > 802.11/a/n/ac > Network : Confirmed that 802.11a Network Status is enabled.
  2. Wireless > All APs > under any APs > Interfaces : RadioSlot#1 is Enabled and Oper Status Up.
  3. Wireless > All APs > under any APs > Advanced : PoE Status says 'Full Power' as my switch support PoE+ at 16.8W
  4. Wireless > Country : SG is selected (that is where I am)
  5. WLAN > (SSID name) > Advanced > Client Band Select is checked.
Some of the troubleshooting steps I did was:
  1. Initially I was running on 8.0.121.0. I upgraded to 8.0.133.0. Didn't help.
  2. I went to Wireless > 802.11/b/g/n > Network : And unchecked 802.11b/g Network status. Still cannot 'see' the 5Ghz network.
  3. WLAN > (SSID name) > General : Change Radio Policy to only 802.11a or 802.11a/g. Not working.
What could I have missed out?
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Looks fine to me.  Is the AP configured with RF Profile?
Ver la solución en mensaje original publicado
7 RESPUESTAS 7
Leo Laohoo
inSSIDer uses the wireless client's on-board wireless NIC card.  The only thing I can think of is the wireless client only has 802.11b-capable wireless NIC.
Exactly, what is the brand and model number of the wireless NIC?
Hi Leo Laohoo, I am using a X230 with a built-in Intel 6205. I am very sure it supports 802.11a as I am using 5Ghz in my home wireless. Other sites I am been to, I am able to see SSIDs on the 5Ghz wireless range.
Please post the complete output to the command "sh sysinfo" & "sh wlan <ID>".
Hi Leo LaoHoo,
Here you go...
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.133.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name...................................... PROCURRI_WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.100.41.3
IPv6 Address..................................... ::
Last Reset....................................... Power on reset
System Up Time................................... 0 days 3 hrs 26 mins 0 secs
System Timezone Location......................... (GMT +8:00) HongKong, Bejing, Chongquing
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... SG - Singapore
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +41 C
External Temperature............................. +45 C
Fan Status....................................... 3500 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 0
Burned-in MAC Address............................ 38:20:56:01:8D:00
Maximum number of APs supported.................. 75
System Nas-Id.................................... Cisco_01:8d:04
WLC MIC Certificate Types........................ SHA1/SHA2
(Cisco Controller) >show wlan 1
WLAN Identifier.................................. 1
Profile Name..................................... PROCURRI_WLAN
Network Name (SSID).............................. PROCURRI
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
Client Profiling Status
Radius Profiling ............................ Disabled
DHCP ....................................... Disabled
HTTP ....................................... Disabled
Local Profiling ............................. Disabled
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
--More-- or (q)uit
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 86400 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... none
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ procurri_wlan
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream Downstream
Average Data Rate................................ 0 0
--More-- or (q)uit
Average Realtime Data Rate....................... 0 0
Burst Data Rate.................................. 0 0
Burst Realtime Data Rate......................... 0 0
Per-Client Rate Limits........................... Upstream Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
--More-- or (q)uit
Radius Servers
Authentication................................ Global Servers
Accounting.................................... Global Servers
Interim Update............................. Enabled
Interim Update Interval.................... 0
Framed IPv6 Acct AVP ...................... Prefix
Dynamic Interface............................. Disabled
Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Radius NAI-Realm................................. Disabled
Security
802.11 Authentication:........................ Open System
FT Support.................................... Enabled
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Disabled
WPA2 (RSN IE).............................. Enabled
TKIP Cipher............................. Disabled
AES Cipher.............................. Enabled
Auth Key Management
802.1x.................................. Disabled
--More-- or (q)uit
PSK..................................... Enabled
CCKM.................................... Disabled
FT-1X(802.11r).......................... Disabled
FT-PSK(802.11r)......................... Disabled
PMF-1X(802.11w)......................... Disabled
PMF-PSK(802.11w)........................ Disabled
FT Reassociation Timeout................... 20
FT Over-The-DS mode........................ Enabled
GTK Randomization.......................... Disabled
SKC Cache Support.......................... Disabled
CCKM TSF Tolerance......................... 1000
WAPI.......................................... Disabled
Wi-Fi Direct policy configured................ Disabled
EAP-Passthrough............................... Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web Authentication Timeout.................... 300
Web-Passthrough............................... Disabled
Mac-auth-server............................... 0.0.0.0
Web-portal-server............................. 0.0.0.0
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
--More-- or (q)uit
FlexConnect Local Switching................... Disabled
FlexConnect Central Association............... Disabled
flexconnect Central Dhcp Flag................. Disabled
flexconnect nat-pat Flag...................... Disabled
flexconnect Dns Override Flag................. Disabled
flexconnect PPPoE pass-through................ Disabled
flexconnect local-switching IP-source-guar.... Disabled
FlexConnect Vlan based Central Switching ..... Disabled
FlexConnect Local Authentication.............. Disabled
FlexConnect Learn IP Address.................. Enabled
Client MFP.................................... Optional
PMF........................................... Disabled
PMF Association Comeback Time................. 1
PMF SA Query RetryTimeout..................... 200
Tkip MIC Countermeasure Hold-down Timer....... 60
Eap-params.................................... Disabled
AVC Visibilty.................................... Disabled
AVC Profile Name................................. None
Flow Monitor Name................................ None
Split Tunnel Configuration
Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
--More-- or (q)uit
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Disabled
802.11v BSS Max Idle Service..................... Enabled
DMS DB is empty
Band Select...................................... Enabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Disabled
Mobility Anchor List
WLAN ID IP Address Status
802.11u........................................ Disabled
MSAP Services.................................. Disabled
Hi Leo LaoHoo,
The 'default-group' is present. After reading from this link, there isn't any RF Profile.
So, I created 2 RF Profiles (one for 802.11a and 802.11bg) under Wireless > RF Profiles.
And under WLANs > Advanced > AP Group, I created a new AP Group with the 2 new RF Profiles and assigned all the APs onto it.
I will check tomorrow if the APs are broadcasting 5Ghz channel.
Will update here...
Hi Leo LaoHoo,
I found out what the issue is and I have resolved it. Apparently the new APs I got were the UX regions and needs to be primed for Singapore to be used. So only 2.4Ghz channel is available.
I managed to prime all my access points and my 5Ghz channel is now broadcasting.
Thanks for your help.
