WLC2504 Guest Web Authentication
mml4cisco
Can we change the internal web authentication for guest network to use http instead of https?
Surendra BG
Yes u can... der s a catch..
1>> if ur running WLC code below 7.2.X then the only option is to disable HTTPS globally (Meaning HTTPS management access disabled only HTTP).
2>> If you are running 7.2.X and above, then you can use HTTP for client webauth and then HTTPS for Management access.
Please let me know if this answered your questions and dont forget to rate the usefull posts!!
Surendra
Surendra BG
Surrendra,
I can't find any documentation from Cisco  on how to configure to allow https for WLC management and http for client webauth. I am on 7.2.X. Can you publish the link to configure this?
JJ
fairly sure the syntax you are looking for is: config network web-auth secureweb disable
It will still require a reboot for the redirector to function, but that will get you HTTPS MGMT and HTTP Web Auth.
