06-08-2019 06:22 AM - edited 07-05-2021 10:32 AM
Built the 5520 in HA, already to go in to production.
I need to add the CICM so followed the instructions https://www.cisco.com/c/en/us/support/docs/wireless/5520-wireless-controller/212170-Console-access-to-5520-8540-WLC-via-CIMC.html
I had to remove the redundancy first configure both boxes as the customer did want a Reserved DHCP address, wanted in their management VLAN, rejoined the SSO.
I can browse to the GUI of the given address to both boxes, but the username and password don't work.
(Cisco Controller) >show imm chassis sol-info
Set in progress : set-complete
Enabled : false
Force Encryption : false
Force Authentication : false
Privilege Level : USER
Character Accumulate Level (ms) : 50
Character Send Threshold : 201
Retry Count : 7
Retry Interval (ms) : 500
Volatile Bit Rate (kbps) : 9.6
Non-Volatile Bit Rate (kbps) : 9.6
Payload Channel : 14 (0x0e)
Payload Port : 623
Any ideas?
cheers
Solved! Go to Solution.
06-08-2019 07:14 AM
06-08-2019 07:14 AM
