working with CT5508
Debudas123
Dear,
i have 12 caps(3602) and one 5508 controller, i have configure all the things, but when i have enable the hight-thoughput (n mode), then no win7 laptops are connecting, but when i will disable it then it is connected with 54 mbps, so what will be the issue.
thanks
Debu
25 Replies 25
I have a feeling your PC's wireless card does not support 802.11n.  I believe it will only support 802.11 b/g and could be falsely advertised as "802.11 b/g/n ready".
this problem is in only win7 laptop, winxp are working fine
thanks
Debu
Can you specify the model of the wireless NIC driver and the version of the drivers?
windows 7 are not connecting, but winxp, macbook and mobiles are connected...
thanks
Debu
This sounds like drivers as well.  Are the Windows 7 clients the same hardware?
Have you tried upgrading the drivers of the Windows 7 wireless NIC?
What happens if you use OPEN authentication, can the Windows 7 client associate?
Atheros AR9285 wilss adaptor
driver version  7.7.0268
different different adaptor are using, in open authentication same problem...
thanks
Debu
Gee whiz.  Your drivers are woefully OUTDATED.
Go here:  http://www.atheros.cz/atheros-wireless-download.php?chipset=37&system=5
Update your drivers and try again.  Your description eliminates wireless issues and continuously points to the wireless card.
same issue after update......
thanks
Debu
Can you post a screen shot of where you are enabling this hight-thoughput (n mode)?
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Describe to me the Windows 7 you are currently using.  I mean how was the OS installed?  Is this OS stright from the MS CD/DVD or is the OS an SOE package?
The fact that WinXP and Win8 works fine but not Win7 means this TOTALLY ELIMINATES your issue as a "wireless" problem.
