07-22-2015 06:40 AM - edited 07-05-2021 03:37 AM
Hello i migrated my standalone wifi netowork to a controlled one.
WLC2504 release is 8.0.120
I have an AES WLAN with radius authentication which (for some clients) only works if I broadcast SSID. If I hide the SSID some clients can't authenticate and I get the error:
AAA Authentication Failure for UserName:dominio\userxxx User Type: WLAN USER
Who can help me?
Tks
Johnny
07-25-2015 02:46 PM
error is not related to what you observed , this is authentication failure for a username , its not related to the WLAN if its broadcasted or not , i think that changing the WLAN from broadcast to non-broadcast is changing the client behaviour with using the the correct username (i dunno)
i can see that the client is using machine-name\user-name as a username , can you confirm that this is correct ? are you using the user authentication only or machin/user authentication ? this is a setting on the client WLAN profile ,
07-25-2015 03:06 PM
Yea doesn't sound like broadcast vs non broadcast issue. Those issues you wouldn't get this far. It sounds like an account or AD issue.
Filter on the client MAC address. Bring it up and check the pem state I bet it says 8021X_REQ. If it does check the account ..
