05-24-2006 08:39 AM - edited 07-04-2021 12:10 PM
hello,
Clients Using WPA/WPA2 and Power Save May Fail to Authenticate.
A hidden configure level command, "dot11 wpa handshake timeout", can be used to increase the timeout between sending the WPA key packets from the default value (100 ms) to a value between 101 and 2000 ms.
But this command does not function...
I cannot what make..
Thank you
05-30-2006 07:33 AM
Are you using airespace controller?
05-31-2006 01:42 AM
No, I must go in the mode configuration, is not this step?
(console: privilege mode then configure mode)
Thank you
05-31-2006 08:27 AM
What is the authentication fail code at your radius server?
