WPA-PSK for Outdoor P2P: What's about broadcat-key?
o-ziltener
Hello
It is recommend to change broadcast key when I use WPA-PSK? If yes, which value in seconds is recommend?
encryption mode ciphers tkip
broadcast-key change XXX
any input is very welcome
dixho
Level 6
Level 6
I suggest you to do enable broadcast key rotation. It really depends on the amount of broadcast/multicast traffic. If you use broadcast and multicast traffic alot, I suggest you to configure slightly less than 2 hours. If not, 10 hours is good enough.
dixho
Level 6
Level 6
