05-19-2019 02:51 AM
Hi fellows, whats your thoughts about this.
As you probably know this is working fin on a 9K router, but fails on a NCS
You may also refer to the VOQ and the usage of qos-groups and output policy on the coresponding interface (core) interface when remarking traffic (IP and or MPLS)
But I would argue that the numbers of qos-groups (8) is not enough and you can not set both mpls exp and ip prec in the same policy/class-map
Anyhow I am not sure if this is suppose to work on a NCS plattform (Jericho) or not, if its a bug or if its a feature that will come later on.
What I'm trying to acheve is basically:
PE, ingress interface: rate limit the traffic and remark all traffic (as the exceed action in the policer is missing too)
on a 9K you would use a 2 lavel policy but that do not work instead I have to either police or remark/classify)
any experience or feedback, is the 2 lavel policy suppose to work?
Running 6.5.3 and apologize if there are any typos in the naming of the Acl/class-maps/policys below as I change the names
Option A
OK, this remark to 0
ipv4 access-list NAME_1
10 permit ipv4 any any
class-map match-any NAME_2
description IPv4 permit any
match access-group ipv4 NAME_1
end-class-map
policy-map CHILD_1
class NAME_2
set traffic-class 0
set precedence 0
class class-default
end-policy-map
Interface
service-policy input CHILD_1
Option B
policy-map CHILD_2
class class-default
set traffic-class 1
set precedence 1
end-policy-map
Interface
service-policy input CHILD_2
Option C
NOK this will not remark to prec 0 only police
policy-map PARENT
class class-default
service-policy CHILD_1
police rate 100 mbps burst 6250 kbytes
end-policy-map
Interface
service-policy input PARENT
Jonas
Solved! Go to Solution.
06-03-2019 07:22 AM - edited 06-03-2019 07:24 AM
Hi, I will test this in the lab, thanks Xander!
Do you know in what version this can be fixed and is it affecting 5500 or just 55A1?//Jonas
06-03-2019 08:37 AM
hi jonas, this is applicable to all ncs55, it was meant to be fixed in 652, but apparently there is a side-effect to it.
hence that tech qos may be useful to see if there is a limitation or a side effect that needs to be addressed.
that also if the workaround is unusable :)
cheers!
xander
06-05-2019 06:41 AM
Hi Xander
thanks, ill go for the option to use the class-default and set TC/IPPrec until this is fixed
a little bit tricky to create any any for ipv4 and ipv6 plus I need to change it back when the bug is fixed
06-05-2019 06:29 AM
Hi Xander,
I will go for the workaround using class-default until the bug is fixed, instead of reconfiguring the ACL's (ipv4 and ipv6)
also when the bug is fixed I don not necessary need to change it back if its class-default
//Jonas
06-05-2019 06:26 AM
Hi Alexandar, uploaded that to the tac case//Jonas
