A9K-20HG-FLEX-TR with A9K-RSP880-LT-TR
PK99
When looking at Cisco Live slides, it states only A99-RSP or A9K-RSP5.  Can the 20HG-FLEX module run on RSP880-LT with x64?
PK99
Sorry, meant A99-RP3 & A9K-RSP5
Fredrik Lonnman
According to the RSP880 datasheet at https://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/datasheet-c78-733763.html it seems like the only supported 5th gen card is the 8HG, not the 20HG.
Thanks.  I'm wondering if that article could be outdated as the 4HG is also not on that list and I would imagine if 8HG works, 4HG should as well.  We are considering the 20HG for the 400G ports and the 100G density
smilstea
No, it's not supported.
The 20HG is a 2TB card and RSP880 only supports 880GB.
Sam
