A9K-4HG-FLEX-FC compatibility
juan-castro
Hello Community,
I've this doubt.
ASR 9010 + RSP 880-TR + IOS XR 7.7.2
   Does this Matrix of Hardware + Software support linecard A9K-4HG-FLEX-FC ?
 Thanks in advance.
ChristopheLucas
Don't know if it can help but 9906+RSP880-SE+ A9K-4HG-FLEX+7.7.2 is used here without any problem.
Sorry but I don't know which is functionnalities of FC cards.
Christophe
tkarnani
slide 28 will give you the speed of dual RSP880 on an 9010
will it work, it should...but the lower RSP880 will not give you any fabric redundancy
the recommendation is to use RSP5 for redundancy
https://www.ciscolive.com/c/dam/r/ciscolive/global-event/docs/2022/pdf/BRKARC-2000.pdf
