931
Beginner
A9k-8T-B not detected after upgrade
We have upgraded our ASR9000 from ios-xr 5.3.4 to 6.2.3, but after the upgrade, ASR chassis does not detect 10G modules (A9K-8T-B) so we had to reload the chassis in order revert to the previous ios-xr version (5.3.4).
i got this log after upgrade to 6.2.3:
shelfmgr[413]: %PLATFORM-SHELFMGR-3-INCOMPATIBLE_LC_FOR_CHASSIS : Node 0/0/CPU0 has an incompatible card_type of 0x40221 for this chassis/RSP type/FC.
1 ACCEPTED SOLUTION
Beginner
Re: A9k-8T-B not detected after upgrade
This card is from Trident family and is not supported on 6.x.x code.
Last supported code for this HW is 5.3.4.
This is the reason this is not booting on 6.2.3 code.
Refer CCO doc for EoL information.
https://www.cisco.com/c/en/us/products/routers/asr-9000-series-aggregation-services-routers/eos-eol-notice-c51-731288.html
Btw, the syslog here is self-explanatory, shelfmgr[413]: %PLATFORM-SHELFMGR-3-INCOMPATIBLE_LC_FOR_CHASSIS : this meaning that card is not compatible to the SW.
Nitin Pabbi (npabbi)
1 REPLY 1
Beginner
Content for Community-Ad
August's Community Spotlight Awards
