11-18-2024 04:04 AM
hi everyone
I need to check if the new 2 A9K-8X100GE-L-SE line cards we bought are good
I inserted the first line card, and it get stuck on IN-RESET state.
and the second is stuck in UNPOWERED state
what could be wrong?
it should be noted that the lines cards are in ASR 9006 with just one power supply because it is in lab environment.
thanks in advance
11-18-2024 04:41 AM
can you post the "show log" output while its booting?
thanks
11-18-2024 04:45 AM
hi
thanks for replying..
i upgraded from version 5.3.2 to 6.4.2 and it did solve the issue but not completley
the issue now is that i can see only 4 100 gig ports instead of 8
