11-25-2018 01:21 AM
Hi gents,
I got the following when inserted ISM module into ASR9k the other day, would you know what is it complaining about?
This line card does not use NPs, and is neither Trident-based nor Typhoon-based so should not complain about too new XR version.
And the mixed mem note can be ignored.
The system is running 6.2.3
Node Type State Config State
0/RSP0/CPU0 A9K-RSP440-SE(Active) IOS XR RUN PWR,NSHUT,MON
0/RSP1/CPU0 A9K-RSP440-SE(Standby) IOS XR RUN PWR,NSHUT,MON
0/0/CPU0 A9K-36x10GE-TR IOS XR RUN PWR,NSHUT,MON
0/4/CPU0 A9K-ISM-100(LCP) IN-RESET PWR,NSHUT,MON
0/7/CPU0 A9K-36x10GE-TR IOS XR RUN PWR,NSHUT,MON
RP/0/RSP0/CPU0:Nov 12 18:04:23.838 : shelfmgr[420]:
%PLATFORM-SHELFMGR_HAL-7-CAN_INFO : Can API: slot 6 online event.
RP/0/RSP0/CPU0:Nov 12 18:04:23.846 : shelfmgr[420]:
%PLATFORM-SHELFMGR-3-INCOMPATIBLE_LC_FOR_CHASSIS : Node 0/4/CPU0 has an incompatible card_type of 0x1000305 for this chassis/RSP type/FC.
RP/0/RSP0/CPU0:Nov 12 18:04:23.848 : shelfmgr[420]:
%PLATFORM-SHELFMGR-3-MIXED_MEMORY_POWERED : Node 0/4/CPU0 is powered, system running mixed line card memory mode RP/0/RSP0/CPU0:Nov 12 18:04:23.848 : shelfmgr[420]:
%PLATFORM-SHELFMGR-3-MIXED_MEMORY_ALARM : System enters mixed line card memory mode RP/0/RSP0/CPU0:Nov 12 18:04:23.849 : shelfmgr[420]:
%PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/4/CPU0 A9K-ISM-100 state:IN-RESET
RP/0/RSP0/CPU0:Nov 12 18:04:23.857 : invmgr[261]: %PLATFORM-INV-6-OIRIN :
OIR: Node 0/4/CPU0 Sn: FOC1832NFHW inserted RP/0/RSP0/CPU0:Nov 12 18:05:09.015 : ce_switch_srv[54]:
%PLATFORM-CE_SWITCH-6-UPDN : Interface 4 (LC_Slot_4) is up RP/0/RSP1/CPU0:Nov 12 18:05:09.186 : ce_switch_srv[54]:
%PLATFORM-CE_SWITCH-6-UPDN : Interface 4 (LC_Slot_4) is up RP/0/RSP0/CPU0:Nov 12 18:05:10.157 : ce_switch_srv[54]:
%PLATFORM-CE_SWITCH-6-UPDN : Interface 4 (LC_Slot_4) is down RP/0/RSP0/CPU0:Nov 12 18:05:10.444 : ce_switch_srv[54]:
Any pointers are very much appreciated
adam
netconsultings.com
::carrier-class solutions for the telecommunications industry::
11-25-2018 05:38 AM
Hi Adam,
unfortunately the last release that supports the ISM module is 5.3.3
you will either need to downgrade or replace it with the VSM module
