03-04-2014 03:29 AM
Hello All,
I'm trying to configure a L2TP tunnel between two ASR9Ks. The configuration is pretty straightforward and the tunnel came up tidy. However I’m unable to pass traffic throught the tunnel. All the traffic if dropped in the inbound interface.
Configuration
interface GigabitEthernet0/0/0/5.100 l2transport
encapsulation dot1q 100
l2vpn
pw-class L2TP-CLASS
encapsulation l2tpv3
protocol l2tpv3 class L2TP-CLASS
ipv4 source 172.25.200.10
transport-mode vlan
xconnect group L2TP
p2p L2TP
neighbor 172.25.200.11 pw-id 654
pw-class L2TP-CLASS
Outputs
RP/0/RSP0/CPU0:A9K-LAB03#sh l2vpn xconnect group L2TP detail
Tue Mar 4 11:27:33.571 WET
Group L2TP, XC L2TP, state is up; Interworking none
AC: GigabitEthernet0/0/0/5.100, state is up
Type VLAN; Num Ranges: 1
VLAN ranges: [100, 100]
MTU 9182; XC ID 0x840006; interworking none
Statistics:
packets: received 0, sent 0
bytes: received 0, sent 0
drops: MTU exceeded 0, other 0
PW: neighbor 172.25.200.11, PW ID 654, state is up ( established )
PW class L2TP-CLASS, XC ID 0x840006
Encapsulation L2TPv3, protocol L2TPv3
PW type Ethernet VLAN, control word disabled, interworking none
PW backup disable delay 0 sec
Sequencing not set
L2TP class L2TP-CLASS, IPv4 source address 172.25.200.10
TOS 0 (reflect disabled), TTL 255, DF bit not set
Path MTU: disabled
Tunnel state connected, remote circuit status up
L2TPv3 Local Remote
Session 792824663 3260689897
Cookie size 0 bytes 0 bytes
Cookie unassigned unassigned
MTU 9182 9182
Control word disabled disabled
PW type Ethernet VLAN Ethernet VLAN
Create time: 04/03/2014 11:23:44 (00:03:43 ago)
Last time status changed: 04/03/2014 11:24:14 (00:03:13 ago)
Statistics:
drops: out of sequence 0, other 0
RP/0/RSP0/CPU0:A9K-LAB03#sh l2tp tunnel detail
Tue Mar 4 11:53:33.658 WET
Tunnel id 715704093 is up, remote id is 3012491936, 1 active sessions
Locally initiated tunnel
Tunnel state is established, time since change 00:13:37
Tunnel transport is IP (115)
Remote tunnel name is A9K-LAB04
Internet Address 172.25.200.11, port 0
Local tunnel name is A9K-LAB03
Internet Address 172.25.200.10, port 0
VRF table id is 0xe0000000
Tunnel group id
L2TP class for tunnel is L2TP-CLASS
Control Ns 18, Nr 18
Local RWS 512 (default), Remote RWS 512
Control channel Congestion Control is disabled
Tunnel PMTU checking disabled
Retransmission time 1, max 1 seconds
Unsent queuesize 0, max 0
Resend queuesize 0, max 2
Total resends 0, ZLB ACKs sent 16
Total out-of-order dropped pkts 0
Total out-of-order reorder pkts 0
Total peer authentication failures 0
Current no session pak queue check 0 of 5
Retransmit time distribution: 0 0 0 0 0 0 0 0 0
Control message authentication is disabled
RP/0/RSP0/CPU0:A9K-LAB03#sh l2tp counters forwarding session
Tue Mar 4 11:55:50.613 WET
LocID RemID TunID Pkts-In Pkts-Out
Bytes-In Bytes-Out
123327359 1688338792 715704093 0 0
0 0
Any idea of what might be wrong?
Cheers,
PM
Solved! Go to Solution.
03-04-2014 04:54 PM
l2tpv3 for ipv4 is not supported on ASR9k ,though l2tpv3ov6 is supported 4.3.1 onwards !!
03-05-2014 07:16 AM
Yes it's supported on CRS,here you go
03-04-2014 04:54 PM
03-04-2014 05:25 PM
Is L2VPN over GRE an option for you? You can look at that.
Eddie.
03-05-2014 02:47 AM
Hi Saurabh, Eddie,
Thanks for your reply.
Could you please confirm if L2TPv3 for IPv4 is supported on CRS? In what version?
Thanks.
PM
03-05-2014 07:16 AM
03-06-2014 03:23 AM
Thx Saurabh!
