Highlighted
Beginner
A9K-RSP5-SE DIE_DIMM3 in failure state
Hello all...our our RSP5-SE we kept getting DIE_DIMM3 ERROR and show alarms gives us this error:
RP/0/RSP0/CPU0:ios#sh alarms detail system active
Wed Sep 30 10:38:32.055 UTC
Active Alarms
Description:             DIE_DIMM3: in a failure state.
AID:                     SM/HW_ENVMON_SENSOR_ALARM/4
Tag String:              FAM_FAULT_TAG_HW_ENVMON_NM_SENSOR_FAULT
Module Name:             N/A
EID:                     CHASSIS/LCC/1:CONTAINER/CC/1:MODULE/RP/1:MODULE/MOTHER_BOARD/1:SENSOR/TEMP/8
Reporting Agent ID:      50
Pending Sync:            false
Severity:                Minor
Status:                  Set
Group:                   Environ
Set Time:                09/30/2020 10:28:41 UTC
Clear Time:              -
Service Affecting:       NotServiceAffecting
Transport Direction:     NotSpecified
Transport Source:        NotSpecified
Threshold Value:         -
Current Value:           -
Bucket Type:             NotSpecified
Event Type:              Default
Interface:               NIL
Alarm Name:              sensor in a failure state
RP/0/RSP0/CPU0:ios#
After doing some digging I learned that the RSP5-SE comes with 40GB ECC Correcting DIMMs.  I removed the metal protective plate to see if maybe moving the DIMMS around would fix this error.  What I learned is:
There are 6 DIMM slots and only 5 DIMM slots were populated.  I looked at the memory modules and they are all 8GB each.  So 5x8GB would equal to the 40GB that Cisco ships the RSP5-SE with so it makes sense as to coming to the 40GB total.  But leaving a DIMM slot open will constantly trigger this DIMM3 error.  Is this a bug in IOSXR x64 6.5.1?  Is this normal/acceptable?  I realize that the error is merely "cosmetic" but still an error.  Any input will be greatly appreciated.
1 ACCEPTED SOLUTION
Highlighted
Right, having the alarm set won't cause any impact on the system.
Sam
8 REPLIES 8
Highlighted
This looks to be fixed via CSCvq17023.
RSP5: Add support for displaying/hiding DIMM. RSP5 TR can have 16G or 24G memory(8+8+8) or (16+8).
Depending on number of DIMMs physically present on board, user should only see corresponding DIMM sensor.
There is some additional wording that they also tested the sensors for -SE cards like you have.
Integrated-releases: 06.06.03 07.00.02 07.01.01 07.02.01
Let me double check with the folks that fixed this to make sure it will fix your condition.
Sam
Highlighted
Thank you Sam.  I would have thought I would only see the sensor for the corresponding DIMMs that are installed on the RSP.  I actually moved the DIMMS around to see if it would trigger the same alarm on the missing slot and it did.  For example, moved DIMM5 to DIMM3, then DIMM5 would show the error.  Moved DIMMs around again and left DIMM2 empty and same error on DIMM2. Below is a Show env all when DIMM3 was empty and you can see that the temp sensor shows "-" (null) as the RSP can't read the temperature because I assume there is no DIMM on slot DIMM3
Location  TEMPERATURE                 Value   Crit Major Minor Minor Major  Crit
          Sensor                        (deg C)   (Lo) (Lo)  (Lo)  (Hi)  (Hi)   (Hi)
0/RSP0
          DIE_FabArbiter0                53    -10    -5     0   115   125   140
          DIE_FabSwitch0                 62    -10    -5     0   115   125   140
          DIE_FabSwitch1                 58    -10    -5     0   115   125   140
          DIE_CPU                        46    -10    -5     0    90    95   110
          DIE_PCH                        49    -10    -5     0    87   100   115
          DIE_DIMM0                      41    -10    -5     0    80    85   100
          DIE_DIMM2                      41    -10    -5     0    80    85   100
          DIE_DIMM3                       -    -10    -5     0    80    85   100
          DIE_DIMM4                      37    -10    -5     0    80    85   100
          DIE_DIMM5                      36    -10    -5     0    80    85   100
          SKYBLT0_Inlet                  43    -10    -5     0    80    85   100
          SKYBLT1_Inlet                  39    -10    -5     0    80    85   100
          High_Power                     58    -10    -5     0    80    85   100
          AIR_Outlet                     48    -10    -5     0    80    85   100
          Inlet                          36    -10    -5     0    70    85   100
          Hotspot                        53    -10    -5     0    90    93    95
          DIE_Aldrin                     61    -10    -5     0   100   110   125
Highlighted
I moved memory out of DIMM3 and now the error is gone but memory is only showing less than 40GB
RP/0/RSP0/CPU0:ios#sh memory summary
Sun Oct 4 09:32:33.728 UTC
node: node0_RSP0_CPU0
Physical Memory: 35123M total (31072M available)
Application Memory : 35123M (29793M available)
Image: 4M (bootram: 0M)
Reserved: 0M, IOMem: 0M, flashfsys: 0M
Total shared window: 131M
RP/0/RSP0/CPU0:ios#
Highlighted
So that bug I quoted only fixes the -TR version of the card, I have just raised a bug to fix the -SE version of the card (CSCvw01617).
I do not have an ETA at this time.
Sam
Highlighted
Thanks so much Sam. I’m guessing this might be just “cosmetic” and is not service affecting.
Highlighted
Sam
Highlighted
I also noticed that no matter where I position the DIMMs only 36GB is being recognized when I issue
show memory summary
Maybe that's a bug too?
Highlighted
So I found this today
https://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/213904-asr9k-exr-show-memory-summary-not-sh.html
Guess this explains why only X amount of memory is being shown on show memory summary
