A9K-RSP5-SE MANAGEMENT PORT
PK99
Ever since we got this unit in our lab (admittedly we never paid attention) but only 1 Management port shows up on
show ip int brief
That port works fine when connected but when the other port is connected, nothing - (pretty obvious since Mgmt1 is not even showing up on show ip int brief
Do we need to RMA this?
2 Accepted Solutions
tkarnani
This is normal, we have this in our lab as well
RP/0/RSP1/CPU0:ASR-9906-C-LS#show interfaces brief  | inc Mg
Sat Jan 30 10:30:33.096 EST
    Mg0/RSP0/CPU0/0          up          up               ARPA  1514    1000000
    Mg0/RSP1/CPU0/0          up          up               ARPA  1514    1000000
RP/0/RSP1/CPU0:ASR-9906-C-LS#show plat
Sat Jan 30 10:30:38.269 EST
Node              Type                       State             Config state
0/RSP0/CPU0       A9K-RSP5-SE(Standby)       IOS XR RUN        NSHUT
0/RSP1/CPU0       A9K-RSP5-SE(Active)        IOS XR RUN        NSHUT
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/ios-xr-software/214945-exr-default-management-interface-mappin.html
smilstea
Yes, that is how it is supposed to look.
Sam
7 Replies 7
tkarnani
So is MGMT ETH 1 not a functional interface?  It doesn't show up on sh ip int brief, but when I connect a cable to it, it lights up.  It even allows me to go into
RP/0/RSP0/CPU0:ios(config)#interface mgmtEth 0/rsp0/cpu0/1
RP/0/RSP0/CPU0:ios(config-if)#no shut
It accepts this but when I try to actually find it, it's not anywhere.
tkarnani
have you checked the admin plane?
admin
show interface
smilstea
The link Tarun provided explains this, in x64-bit because we have different VMs between xr and admin(sysadmin) there is a need for a mgmt port for each VM. So Mgmt port 0 is still used for the regular xr vm and mgmt port 1 is used in sysadmin. This is expected behavior you are seeing.
Sam
Here is my output (disregard the 400G-DWDM Interfaces
RP/0/RSP0/CPU0:ios#sh interfaces brief
Wed Feb 3 11:07:01.309 UTC
Intf Intf LineP Encap MTU BW
Name State State Type (byte) (Kbps)
Nu0 up up Null 1500 0
Mg0/RSP0/CPU0/0 admin-down admin-down ARPA 1514 10000
Hu0/0/0/20/0 admin-down admin-down ARPA 1514 100000000
Hu0/0/0/21/0 admin-down admin-down ARPA 1514 100000000
Te0/0/0/0 admin-down admin-down ARPA 1514 10000000
Te0/0/0/1 admin-down admin-down ARPA 1514 10000000
Te0/0/0/2 admin-down admin-down ARPA 1514 10000000
Te0/0/0/3 admin-down admin-down ARPA 1514 10000000
Te0/0/0/4 admin-down admin-down ARPA 1514 10000000
Te0/0/0/5 admin-down admin-down ARPA 1514 10000000
Te0/0/0/6 admin-down admin-down ARPA 1514 10000000
Te0/0/0/7 admin-down admin-down ARPA 1514 10000000
Te0/0/0/8 admin-down admin-down ARPA 1514 10000000
Te0/0/0/9 admin-down admin-down ARPA 1514 10000000
Te0/0/0/10 admin-down admin-down ARPA 1514 10000000
Te0/0/0/11 admin-down admin-down ARPA 1514 10000000
Te0/0/0/12 admin-down admin-down ARPA 1514 10000000
Te0/0/0/13 admin-down admin-down ARPA 1514 10000000
Te0/0/0/14 admin-down admin-down ARPA 1514 10000000
Te0/0/0/15 admin-down admin-down ARPA 1514 10000000
Te0/0/0/16 admin-down admin-down ARPA 1514 10000000
Te0/0/0/17 admin-down admin-down ARPA 1514 10000000
Te0/0/0/18 admin-down admin-down ARPA 1514 10000000
Te0/0/0/19 admin-down admin-down ARPA 1514 10000000
RP/0/RSP0/CPU0:ios#admin
Wed Feb 3 11:08:00.108 UTC
admin connected from 192.0.0.4 using ssh on sysadmin-vm:0_RSP0
sysadmin-vm:0_RSP0# show interface
Wed Feb 3 11:08:03.890 UTC+00:00
MgmtEth0/RSP0/0/0 Link encap: Ethernet HWaddr 06:6f:2f:9e:2d:9b
inet addr: 0.0.0.0
UP RUNNING BROADCAST MULTICAST MTU:1500 Metric:1
RX packets: 0 errors:0 dropped:0 overruns:0 frame:0
TX packets: 6 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes: 0 TX bytes: 488
sysadmin-vm:0_RSP0#
Look normal?
smilstea
Sam
Sam and Tarun, thank you both!
