ABF is not supported for incoming labelled/MPLS packets on ASR9K
Dear All
 I have issue with ABF for incoming traffic with label. And from my research I found this word "ABF is not supported for incoming labelled/MPLS packets." in this forum. I just want to make sure this is still not support or it work right now. In case not support how I can do for workaround.
Thank you
Pichet
xthuijs
hi pichet, check CSCuy08854 for the integration of that functionality (ACL support, hence abf, for labeled packets).
on the side, XR530 has the ability to match via PBR on labeled packets.
xander
xthuijs
xander
