12-22-2015 02:33 PM
Hi Everyone,
After going through the documentation for the 9000v, I'm wondering if it's possible to setup the following scenario without using nV Edge. I have a pair of ASR9912 which are configured as standalone units. We have received 3 ASR9000v which we would like to configured in an Active/Standby scenario as part of a customer requirement.
There's a diagram in this link: https://supportforums.cisco.com/document/9868421/asr9000xr-using-satellite-technote which shows the scenario, but it looks like a VSS deployment. In the same document, section 13 describes a Dual-Host configuration. I'm wondering if this is what I am looking for. Will the GigE Interfaces on the "standby" system be in a shutdown state? I'd be worried about some conflicts.
I won't have the second 9912 up and running until Mid-January due to power and rack space, so I can't test until then.
Has anyone successfully deployed this scenario without using nV Edge?
Thanks.
--Dominique
Solved! Go to Solution.
12-22-2015 08:54 PM
Dom,
We prefer you evaluate Advanced Dual Home, which is a new feature. You won't need to use NV EDGE and we're actually advocating customers away from this technology to something more standards based. Take a look at the following:
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-3/nV/configuration/guide/b_nv_cg53xasr9k/b_nv_cg53xasr9k_chapter_01.html#concept_C0306D33E7024B19A21604B8E380289A
Eddie.
12-30-2015 07:56 AM
please ignore.
12-22-2015 08:54 PM
Dom,
Eddie.
12-30-2015 07:54 AM
Hi Eddie,
Thanks for the link to the updated method.
--Dominique
12-30-2015 07:56 AM
please ignore.
