address-family rtfilter unicast missing on ASR9k
amarhold
Hello !
I found out and pls correct me, if that is wrong that address-family rtfilter unicast is supported on IOS and IOS-XE but on IOS-XR it is only supported on the CRS1 and XR12000 BUT not on the ASR9k
Are there plans or versions when RT-filter feature will be available for ASR9k as well ?
with best regards
alexander marhold
Nagendra Kumar Nainar
Hi Alexander,
BGP RT constraint is a platform independent feature and I beleive it should be supported in 9K. Are you seeing any issue while configuring the same?.
-Nagendra
Hi Alexander,
-Nagendra
Yes it works on actual asr9k- versions, I tested
it is :
address-family ipv4 rt-filter
alexander
