Archiving Logging message on Local Storage device not work XR 4.3.2
satitcha
Hi XR folks,
I enabled this feature on XR 4.3.2 as following configuration,
logging archive
 device harddisk
 severity notifications
 file-size 5
 frequency daily
 archive-size 100
 archive-length 4
The issue is,
There have no Archiving logging file be generated on each weekly directory as following output command.
RP/0/RSP1/CPU0:ASR9010#dir harddisk:/var/log/2015/02 location 0/RSP0/CPU0
Fri Feb 20 14:08:43.822 BKK
Directory of net/node0_RSP0_CPU0/harddisk:/var/log/2015/02
20562674    drwx  4096        Sun Feb  1 07:00:00 2015  01
20562675    drwx  4096        Sun Feb  8 07:00:00 2015  08
6576652288 bytes total (5195808256 bytes free)
RP/0/RSP1/CPU0:ASR9010#dir harddisk:/var/log/2015/02/01 location 0/RSP0/CPU0
Fri Feb 20 14:09:55.756 BKK
Directory of net/node0_RSP0_CPU0/harddisk:/var/log/2015/02/01
No files in directory
6576652288 bytes total (5195806208 bytes free)
RP/0/RSP1/CPU0:ASR9010#dir harddisk:/var/log/2015/02/08 location 0/RSP0/CPU0
Fri Feb 20 14:10:00.169 BKK
Directory of net/node0_RSP0_CPU0/harddisk:/var/log/2015/02/08
6576652288 bytes total (5195805696 bytes free)
Could anyone can suggest me to troubleshoot for root cause of this issue.
Thank you in advance,
Satit
satitcha
Hi XR Folks,
Anyone used to face this symptom ?
Please share your idea.
Thank you in advance.
Satit
Hi folks,
I'm suspecting if any issue on path harddisk and logging severity,
So i changed the path to disk1 , as following configuration.
logging archive
device disk1
severity debugging
file-size 5
frequency daily
archive-size 100
archive-length 4
I found new symptom,
The log file was created, but Zero bytes of content of file.
RP/0/RSP0/CPU0:PN1#dir
Wed Feb 25 13:23:27.697 BKK
Directory of disk1:/var/log/2015/02
49818       drwx  4096        Wed Feb 25 10:45:51 2015  22
12884885504 bytes total (12881689600 bytes free)
RP/0/RSP0/CPU0:PN1#cd 22
Wed Feb 25 13:23:31.016 BKK
Directory of disk1:/var/log/2015/02/22
49882       -rw-  0           Tue Feb 24 17:10:22 2015  syslog.24.1
49883       -rw-  0           Wed Feb 25 10:45:51 2015  syslog.25.1
RP/0/RSP0/CPU0:PN1#more disk1:/var/log/2015/02/22/syslog.24.1
Wed Feb 25 13:24:05.464 BKK
Wed Feb 25 13:24:07.519 BKK
Satit
