Sumanta Ghosh
Beginner
Are A9K-4X100GE and A99-12X100GE supported on ASR9910 with A99-RSP-SE?
Hi Experts,
Do these line cards - A9K-4X100GE and A99-12X100GE, supported on ASR9910 with A99-RSP-SE, running A99-SFC-S? Datasheets are not giving complete info in details. The SE and TR LCs only support CPAK and we need QSFP.
Both are Tomahawk series 3rd generation LC, are they?
Sumanta.
2 REPLIES 2
balaji.bandi
VIP Master
As i remember they do support QSFP - If you concern still, ask your partner before place an order.
A9K-4X100GE - yes it is :
https://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/datasheet-c78-740092.html
A99-12X100GE - Yes
https://www.cisco.com/c/en/us/products/collateral/routers/asr-9000-series-aggregation-services-routers/datasheet-c78-737623.html
BB
How to Ask The Community for Help
Hi Balaji,
Thanks.
What will be bandwidth per slot if we use ASR 9910 with 2 x A99-RSP-SE? Accordingly, we need to add more fabric cards to achieve line rate for above LCs such as 4 x 100 GE or 12 x 100 GE? If we have all 5 x SFC-S cards, does it mean it will give 1150 Gbps to each line card?
The Cisco datasheet has below details, but not much explanation how to calculate that.
●  12 Tbps (non-redundant) switching capacity per ASR 9910 router
●  11 Tbps (N+1 redundant) switching capacity per ASR 9910 router
●  1610 Gbps (non-redundant) switching capacity per ASR 9910 line card slot
●  1380 Gbps (N+1 redundant) switching capacity per ASR 9910 line card slot
●  230 Gbps bidirectional switching capacity per RSP to each line card slot
●  Control of up to seven switch fabrics (two located on the RSP and five on dedicated switch fabric cards)
●  Offers traffic load balancing simultaneously across up to seven fabrics
Sumanta.
