ASR 9000 Layer 2 connectivity problem
hammoudatunisia
Hi all,
I have a problem of Layer 2 connectivity which is like this:
I have a 3750 switch, ASR 9010, ASR 1006 that are connected like this:
Switch 3750 --------------------- ASR 9010 ---------------- ASR 1006
The problem is that I cannot ping from Switch 3750 to ASR 1006 .
I am using ASR 9010 like a Layer 2 switch. The configurations are like this:
Switch 3750
interface Tengigabit 0/0/0    /interface connected to ASR 9010/
no switchport
ip address 10.2.1.1  255.255.255.0
ASR 9010
interface Tengigabit 0/0/0/0     /interface connected to Switch 3750/
cdp
interface Tengigabit 0/0/0/0.2 l2transport
encapsulation dot1q 2 exact
rewrite ingress tag pop 1 symmetric
interface Tengigabit 0/0/0/1     /interface connected to ASR 1006/
cdp
interface Tengigabit 0/0/0/1.2 l2transport
interface BVI2
ipv4 address 10.2.1.254 255.255.255.0
l2vpn
bridge group VL2
  bridge-domain VL2
   routed interface BVI2
ASR 1006
interface Tengigabit 0/1/0     /interface connected to ASR 9010/
ip address 10.2.1.2  255.255.255.0
All the interfaces have been enabled with the command [no shutdown] . Also when I issue the command [show ip interface brief] in Switch 3750 or ASR 1006, I found the interfaces in the up/up state.
Can someone please tell me what I am missing? I want to get this logical topology:
Switch 3750-------------------VLAN 2----------------------ASR 1006
Thank you all.
Mohamed Nidhal Beyrem Jaziri
CCIE Routing & Switching 38232
Tunisia
Mohamed Nidhal Beyrem Jaziri CCIE Routing & Switching 38232 Tunisia
Ahmed Moshref
From the A9K you are matching on Tag 2 that is not tagged from 1K or switch
8 Replies 8
Ahmed Moshref
Thank You Ahmed for your quick reply.
What must I do in Swtch 3750 and ASR 1006 to tag the frames as they go to ASR 9010?
Tunisia
Ahmed Moshref
There is alots of things to do for this easier and simpler
However for you setup to work you need From 3750 to pass tagged you shall configure int to 9k as trunk
And put the IP address under interface vlan2 also create vlan 2 on switch
You wil have to do same from 1K but with efp and rewrite functions.
I can send you configuration tommorow if you got stucked
Thank you Ahmed,
I agree with you that we can use an easier solution with simply routed ports on Switch 3750, ASR 9010 and ASR 1006, but the goal of the configuration is to use the ASR 9010 as a switch.
Do you think that this configuration will work:
Switch 3750
vlan 2
switchport mode trunk
interface vlan 2
ASR 9010
Same configuration as above
ASR 1006
no ip address
cdp
interface Tengigabit 0/1/0.2 l2transport
Tunisia
For the above you will still have to create bvi on ASR1K and map the subinterface with the bvi on the same bridge domain/group
Thanks Ahmed Moshref
Thanks Ahmed,
We forgot that ASR 1006 runs with IOS-XE and not IOS-XR, therefore we can't use the EFP concept. But what do you think about this configuration:
ASR 1006
no ip address
encapsulation dot1Q  2
Tunisia
hammoudatunisia
Here is the final and functional config, I tested it in this morning and it is working:
Switch 3750
vlan 2
interface vlan 2
interface TenGigabitEthernet1/0/1
ASR 9010
ASR 1006
no ip address
Thank you all
Tunisia
Good that you get it done! :)
