07-26-2013 01:13 AM
How can I show statistics when I use shapeing on interface level. With police it is clear e.g
sh policy-map interface TenGigE 0/0/0/0 output
give me some statistics about conform and exceeded traffic but when I configure
shapeing like below:policy-map p-map
class class-default
shape average 6 gbps !
end-policy-map
How can I show some statistics about peaks above.
I ask because output is a bit misterious for mesh qos interface tenGigE 0/0/0/0 outputInterface: TenGigE0_0_0_0 output
Bandwidth configured: 6000000 kbps Bandwidth programed: 6000000 kbps
ANCP user configured: 0 kbps ANCP programed in HW: 0 kbps
Port Shaper programed in HW: 6000000 kbps
Policy: p-map Total number of classes: 1
Level: 0 Policy: p-map Class: class-default
QueueID: 0 (Priority Normal)
Queue Limit: 0 kbytes Profile: 0 Scale Profile: 0
I cant see anyting from that output ?
07-29-2013 05:11 AM
Which IOX are you using?
I have just tried this on my 9k platform , and it showd stats
interface POS0/0/0/0
service-policy output p-map
encapsulation ppp
pos
crc 16
load-interval 30
policy-map p-map
class class-default
shape average 20 mbps
end-policy-map
RP/0/RSP0/CPU0:EQUINOX-A9k#show policy-map interface pos 0/0/0/0 output
Mon Jul 29 04:40:36.655 UTC
POS0/0/0/0 output: p-map
Class class-default
Classification statistics (packets/bytes) (rate - kbps)
Matched : 4/48 0
Transmitted : 0/0 0
Total Dropped : 0/0 0
Queueing statistics
Queue ID : 3758096386
High watermark (Unknown)
Inst-queue-len (bytes) : 0
Avg-queue-len (Unknown)
Taildropped(packets/bytes) : 0/0
I am currently working with 4.2.3
Thank You
Ahmed Moshref
07-30-2013 11:39 PM
My IOS XR version is also 4.2.3. When run
Wed Jul 31 08:36:42.204 MET
TenGigE0/0/0/0 direction output: Service Policy not installed
But like in command above show qos .... I got some results. Strange isn't it ?
08-07-2013 01:03 PM
If you just want to make this work, move the shaper to parent level:
policy-map dummy
class class-default
bandwidth percent 100
end-policy-map
policy-map p-map
class class-default
service-policy dummy
shape average 500 mbps
end-policy-map
With this modification, your policy will be correctly applied.
I'm not sure why it doesn't work with the original config, I would have to look it up. What is the LC type on which you are trying to apply the policy?
/Aleksandar
08-13-2013 01:46 AM
I just ran into the same problem on A9K6/RSP440(TR)/MOD80(TR) running XR 4.3.1:
Before dummy-config:
-----snip-----
interface GigabitEthernet0/0/1/0
bandwidth 100000
cdp
service-policy output Shape-to-100M
ipv4 address
negotiation auto
carrier-delay up 2000 down 0
load-interval 30
dampening
RP/0/RSP0/CPU0:
Tue Aug 13 09:28:54.079 UTC
policy-map Shape-to-100M
class class-default
shape average 95000000 bps
end-policy-map
RP/0/RSP0/CPU0:
Tue Aug 13 09:37:30.831 UTC
GigabitEthernet0/0/1/0 direction output: Service Policy not installed
-----snap-----
After dummy-config:
-----snip-----
bandwidth 100000
cdp
ipv4 address
negotiation auto
load-interval 30
dampening
RP/0/RSP0/CPU0:
Tue Aug 13 09:42:13.765 UTC
policy-map dummy
class class-default
end-policy-map
class class-default
end-policy-map
RP/0/RSP0/CPU0:
Tue Aug 13 09:43:12.887 UTC
GigabitEthernet0/0/1/0 output: Shape-to-100M
Class class-default
Matched : 626092/543729402 10849
Transmitted : 627073/544823300 9379
Policy dummy Class class-default
Queueing statistics
Queue ID : 418
High watermark : N/A
Inst-queue-len (packets) : 0
Avg-queue-len : N/A
Queue(conform) : 627073/544823300 9379
Queue(exceed) : 0/0 0
RED random drops(packets/bytes) : 0/0
RP/0/RSP0/CPU0:
-----snap-----
Thanks for the tip with the dummy child policy!
Do you know if there's an existing bug report for this weirdocity? - or should I report it?
Cheers!
Mikkel
08-13-2013 06:34 AM
Hi Mikkel,
glad to hear that this is working now.
This is actually behaviour per design. Without a queueing action at child level, shaper profile is not created.
If you check the output from the very start of the thread, you don't see any shaper profiles:
If you run the same command now that there is a dummy child policy with BW allocation, you will see that a Level0 a shaper profile was created. This shaper profile is applied to all queues at Level1 of this policy.
I couldn't find any documents where this restriction is listed, though. I'll see what can be done about that.
/Aleksandar
08-23-2013 01:36 PM
Thanks, Aleksandar!
An update to the documentation would indeed be welcome.
Cheers,
Mikkel
08-26-2013 05:37 AM
Hi Mikkel,
document ASR9000/XR: Understanding QOS on the A9K platform, default marking behavior, troubleshooting has been updated. Please see the "Port level shaping" section. I hope this addresses your concern.
Rgds,
Aleksandar
09-06-2013 05:20 AM
Hi Mikkel,
CCO document Configuring Modular QoS Congestion Management will also be updated soon.
Aleksandar
