Enthusiast
ASR 9000 XR, ip igmp snooping querier
Is there any similar solution like in Cisco 7600, where you can put in the "ip igmp snooping querier" under the SVI to get the local Multicast feature if you dont need the Multicast routing support more than for the local vlan.
So in the following interaface, that is terminationg the vlan, there need to be a igmp snooping querier to solve the mrouter port in the catalyst 6500 world like in the link below
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008059a9df.shtml
interface Bundle-Ether300.1
vrf 201
ipv4 address 192.168.5.3 255.255.255.0
encapsulation dot1q 1
Is there a solution to this in the ASR 9000, XR if you don't want/need to activate full  multicast-routing ?
1 REPLY 1
Highlighted
Yes it is supported on the ASR9k but all IGMP snooping config is done at the Bridge-domain level. Please refer to the following link for the details:
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.1/multicast/configuration/guide/mc41igsn.html
Laurent.
Content for Community-Ad
August's Community Spotlight Awards
