10-15-2014 01:44 PM
Hello everyone,
For example: IOS
7609:
inter vlan 7
ip add 7.7.7.7/24
inter vlan 8
ip add 8.8.8.8/24
inter vlan 9
ip add 9.9.9.9/24
inter vlan x
ip add x.x.x.x/24
inter gi0/1
des # TRUNK sw-3750-01
swit mode trunk
swi trunk all vlan 7,8,9,..x
inter gi0/2
des # TRUNK sw-3750-02
swit mode trunk
ASR 9001
inter gi0/0/1/0
inter gi0/0/1/0.7 l2protocol
encap dot1q 7
rew ingre tag pop 1 symetric
inter gi0/0/1/0.8 l2protocol
encap dot1q 8
inter gi0/0/1/0.9 l2protocol
encap dot1q 9
inter gi0/0/1/1
inter gi0/0/1/1.7 l2protocol
encap dot1q 7
inter gi0/0/1/1.8 l2protocol
encap dot1q 8
inter gi0/0/1/1.9 l2protocol
encap dot1q 9
inter bvi 7
ipv4 add 7.7.7.7/24
inter bvi 8
ipv4 add 8.8.8.8/24
inter bvi 9
ipv4 add 9.9.9.9/24
l2vpn
bridge group VLAN7
bridge-domain VLAN7
interface gi0/0/1/0.7
interface gi0/0/1/1.7
routed interface bvi 7
bridge group VLAN8
bridge-domain VLAN8
interface gi0/0/1/0.8
interface gi0/0/1/1.8
routed interface bvi 8
bridge group VLAN9
bridge-domain VLAN9
interface gi0/0/1/0.9
interface gi0/0/1/1.9
routed interface bvi 9
etc...
My question : Is there any way to do this on XR in a shorter way, There is a lot of configuration if we have more vlans.
Nenad
11-14-2014 12:14 PM
Hello Nenad,
if BVI is needed then yes, you need to configure ever VLAN individually and pop tags there as BVI understands only untagged traffic.
If BVI is not needed then you make trunk subinterfaces matching set of VLANs.
Example matching range 100 to 300:
! interface TenGigE1/0/0/4.100 l2transport encapsulation dot1q 100-300 ! interface TenGigE0/0/0/4.100 l2transport encapsulation dot1q 100-300 ! l2vpn bridge group VLAN bridge-domain 99 interface TenGigE1/0/0/4.100 ! interface TenGigE0/0/0/4.100 !
/A
11-17-2014 10:33 PM
Hello Nenad,
You may also like to go through the below mentioned document.
L2 Switching Configuration to XR L2VPN Configuration Conversion Process
http://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/116500-problemsolution-product-00.html
