ASR 9906 NV Edge IRL
jwjorgensen
Level 4
Level 4
I read on a doc this morning on nv edge that the IRLs had to be 40 or 100 GE but then I read on another doc that they can be 10GE links.  Can someone clarify for me?
Thanks in advance!
JJ
Hi, NV cluster is not supported with 6.3.2 + Tomahawk cards
7 Replies 7
tkarnani
for Nv edge cluster.
the last supported release is 5.3.4 and the line cards supported are only Typhoon based (thanks Sam, for correction)
https://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/116726-qanda-product-00.html#anc3
Trident is not supported, only typhoon.
SW requirement
  • Supported since 4.2.1
  • Requires cluster software license on each chassis
HW requirement – Chassis
  • Only ASR 9006 and 9010 are supported in 4.2.x
  • ASR 9001 is supported starting in 4.3.0
  • ASR 9001-S and 9922 are supported starting in 4.3.1
  • ASR 9904 and 9912 are supported starting in 5.1.1
  • Only like-like chassis are supported
HW requirement – Line card and RSP
  • Dual RSP440 for 9006/9010/9904
  • Dual RP for 9912/9922
  • Single RSP 9001/9001-S
  • No RSP-4/8G support
  • Only Typhoon LC and SIP-700 allowed to boot
  • Only Typhoon LC support IRL
  • VSM/ISM not supported
To answer the 10G/40G/100G question yes all are supported.
  • 40/100G IRL will be supported starting 5.1.1
  • Mixed mode not supported
Sam
I've got a pair of 9906's running 6.3.2, RSP880s, and Tomahawk linecards (24x10GE-1GE).  Is this a supported configuration?
Thanks for the info!  Just for my knowledge, and to explain to my customer, do you have insight as to why this is not supported in the later releases?
There is a trend moving towards vendor agnostic EVPN where we can use BGP to achieve active/active or active/standby forwarding between two PEs
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-2/lxvpn/configuration/guide/b-l2vpn-cg-asr9000-62x/b-l2vpn-cg-asr9000-62x_chapter_01011.html#concept_5A93CE8A263C4D8FBA0F8E521FC6E854
Aleksandar Vidakovic
Can you share the URL to that document? Was it maybe specific to ncs5000 as satellite?
/Aleksandar
