Aaron_un
Beginner
ASR 9906 NV Edge
I was about to order two 9906 chassis with two RSP880 each
I red here that they don't support nV Edge on 3rd gen cards?! is that still the case?
https://community.cisco.com/t5/xr-os-and-platforms/asr-9906-nv-edge-irl/td-p/3706336
on this slide it says "No support for nV-Cluster and 3rd party applications for RSP880-LT" for LT models only!!! it doesn't say anything about RSP880..
1 ACCEPTED SOLUTION
RSP880 does have the cluster ports but 1. it is not supported on any RSP880 variant 2. it was never tested 3. the code to support it on the rsp880 probably doesn't exist either and 4. if you open a support case with TAC while running this setup you will be asked to revert to supported hardware.
I would recommend looking into EVPN for active-active dual-PE setups.
Sam
2 REPLIES 2
Aaron_un
Beginner
https://community.cisco.com/t5/xr-os-and-platforms/which-technology-hardware-can-replace-nv-cluster/td-p/3765623
Sam
