03-17-2021 02:37 AM - edited 03-18-2021 01:09 AM
Cisco ASR9001
we got аn error when try to upgrade from 6.3.3 to 6.7.3;
install operation 42* from the Logfile.
then tried to upgrade from Version 6.5.3 to 6.7.3 but no go - Install operation 43 and 49
can you suggest where we did mistake ?
here a cut from the log and attached show install log detail:
RP/0/RSP0/CPU0:111(admin)#install add tar
> disk1:ASR9K-iosxr-px-k9-6.7.3.ta$
> Sun Mar 14 09:18:01.143 MET
> Install operation 42 '(admin) install add tar
> /disk1:ASR9K-iosxr-px-k9-6.7.3.tar activate synchronous' started by user
> 'admin' via CLI at 09:18:01 MET Sun Mar 14 2021.
> Info: The following files were extracted from the tar file
> Info: '/disk1:ASR9K-iosxr-px-k9-6.7.3.tar' and will be added to the
> entire
> Info: router:
> Info:
> Info: README-ASR9K-iosxr-px-k9-6.7.3.txt (skipped - not a pie)
> Info: asr9k-video-px.pie-6.7.3
> Info: asr9k-services-px.pie-6.7.3
> Info: asr9k-services-infra-px.pie-6.7.3
> Info: asr9k-optic-px.pie-6.7.3
> Info: asr9k-mpls-px.pie-6.7.3
> Info: asr9k-mini-px.pie-6.7.3
> Info: asr9k-mgbl-px.pie-6.7.3
> Info: asr9k-mcast-px.pie-6.7.3
> Info: asr9k-li-px.pie-6.7.3
> Info: asr9k-k9sec-px.pie-6.7.3
> Info: asr9k-fpd-px.pie-6.7.3
> Info: asr9k-doc-px.pie-6.7.3
> Info: asr9k-bng-px.pie-6.7.3
> Info: asr9k-asr9000v-nV-px.pie-6.7.3
> Info:
> Part 1 of 2 (add software): Started
> / 1% complete: The operation can still be aborted (ctrl-c for options)
> Error : Uncompression of the image failed.
> invalid compressed data--format violated
> RP/0/RSP0/CPU0:Mar 14 09:25:33.931 MET: instdir[262]:
> %INSTALL-INSTMGR-3-INSTALL_OPERATION_SYSTEM_ERROR_SPECIFIC_NODES_HDR :
> Error occurred during install operation 42: Please collect diagnostic
> information using 'show tech-support install'. Use 'show install log 42
> detail' for more details.
> Error: The install operation failed due to a system error.
> Error:
> Error: ERROR: Node responded with an error when completing the
> installation
> Error: of packages within the system. (Details: 'Package Library'
> detected
> Error: the 'fatal' condition 'can't uncompress pie archive')
> Error: AFFECTED NODE(S): 0/RSP0/CPU0
> Error: TECH SUPPORT:
> Error: Please collect diagnostic information using '(admin) show
> Error: tech-support install'
> options)RP/0/RSP0/CPU0:Mar 14 09:25:33.931 MET: instdir[262]:
> %INSTALL-INSTMGR-3-INSTALL_OPERATION_SYSTEM_ERROR_SPECIFIC_NODES :
> 0/RSP0/CPU0 (Node responded with an error when completing the
> installation of packages within the system. (Details: 'Package Library'
> detected the 'fatal' condition 'can't uncompress pie archive'))
> Error:
> Error: The following pies were not added due to an error:
> Error: asr9k-services-infra-px.pie-6.7.3
> Error: asr9k-optic-px.pie-6.7.3
> Error: asr9k-mpls-px.pie-6.7.3
> Error: asr9k-mini-px.pie-6.7.3
> Error: asr9k-mgbl-px.pie-6.7.3
> Error: asr9k-mcast-px.pie-6.7.3
> Error: asr9k-li-px.pie-6.7.3
> Error: asr9k-k9sec-px.pie-6.7.3
> Error: asr9k-fpd-px.pie-6.7.3
> Error: asr9k-doc-px.pie-6.7.3
> Error: asr9k-bng-px.pie-6.7.3
> Error: asr9k-asr9000v-nV-px.pie-6.7.3
> Part 1 of 2 (add software): Failed. Error information available as part of
> command output above. For more information see '(admin) show install log 42'
> Part 2 of 2 (activate software): Skipped due to failures in part 1
> - 10% complete: The operation can still be aborted (ctrl-c for
> options)RP/0/RSP0/CPU0:Mar 14 09:25:33.953 MET: instdir[262]:
> %INSTALL-INSTMGR-3-INSTALL_OPERATION_USER_ERROR : User error occurred
> during install operation 42. See 'show install log 42 detail' for more
> information.
> Install operation 42 failed at 09:25:34 MET Sun Mar 14 2021.
Solved! Go to Solution.
03-17-2021 06:06 PM
I found this old thread with the same issue:
https://community.cisco.com/t5/xr-os-and-platforms/ios-xr-9001-ios-upgred/td-p/4019052
It seems to imply that the tar file is corrupt, can you compare the md5 on the router to the download site tar md5?
On the router issue show md5 file /disk1:/<filename>
Sam
03-17-2021 06:23 AM
You can't jump from 6.3 to 6.7. I had same problem in the past. Had to go to 6.4 to 6.5 to 6.7. I believe it is because some of the fpga dll versions don't meet the minimum version requirements that 6.7 is looking for. Try to migrate in steps, that should take care of your problem.
03-17-2021 09:58 AM
we are currently on 6.5.3 but did not work again. see Install operation 49 from the log l attached in first message;
Install operation 49 started by user 'admin' via CLI at 12:32:18 MET Sun
Mar 14
2021.
(admin) install add tar /disk1:ASR9K-iosxr-px-k9-6.7.3.tar activate
synchronous
Install operation 49 failed at 12:39:37 MET Sun Mar 14 2021.
Install logs:
Install operation 49 '(admin) install add tar
user
'admin' via CLI at 12:32:18 MET Sun Mar 14 2021.
Info: entire router:
Info:
Info:
Error:
Error: installation of packages within the system. (Details:
'Package
Error: Library' detected the 'fatal' condition 'can't uncompress pie
Error: archive')
Error:
part of
install log
49'
03-17-2021 06:06 PM
Sam
