05-11-2022 07:23 AM
I have 2 ASR9000 running 6.4.2 SP10 which im trying to bring up an EVPN Anycast IRB setup in the default routing table.
Ive created the EVPN and have 2 hosts, one behind either PE and they can see each other at layer2 and communicate across the EVPN fine. Ive also added anycast IRB GW's on both of the PE's but PE-A cant see the ARP for the test host behind PE-B and vice-versa.
PE-1
RP/0/RSP0/CPU0:PE-A#show evpn evi mac Wed May 11 15:10:39.115 BST EVI MAC address IP address Nexthop Label ---------- -------------- ---------------------------------------- --------------------------------------- -------- 1000 0015.c546.ffb6 xxx.xxx.17.51 Bundle-Ether1000.400 24073 1000 0021.70c6.435a xxx.xxx.17.50 xxx.xxx.115.216 24012
RP/0/RSP0/CPU0:PE-A#sh arp Wed May 11 15:12:11.018 BST ------------------------------------------------------------------------------- 0/1/CPU0 ------------------------------------------------------------------------------- Address Age Hardware Addr State Type Interface xxx.xxx.17.49 - 0000.3030.0001 Interface ARPA BVI1000 xxx.xxx.17.51 00:00:24 0015.c546.ffb6 Dynamic ARPA BVI1000
RP/0/RSP0/CPU0:PE-A# interface BVI1000 interface BVI1000 host-routing interface BVI1000 ipv4 address xxx.xxx.17.49/29 interface BVI1000 mac-address 0.3030.1 l2vpn bridge group CUST-1000 l2vpn bridge group CUST-1000 bridge-domain CUST-1000 l2vpn bridge group CUST-1000 bridge-domain CUST-1000 mac withdraw state-down l2vpn bridge group CUST-1000 bridge-domain CUST-1000 interface Bundle-Ether1000.400 l2vpn bridge group CUST-1000 bridge-domain CUST-1000 routed interface BVI1000 l2vpn bridge group CUST-1000 bridge-domain CUST-1000 evi 1000 evpn evi 1000 evpn evi 1000 bgp evpn evi 1000 bgp route-target import 1000:1 evpn evi 1000 bgp route-target export 1000:1
RP/0/RSP0/CPU0:PE-A#sh run int BVI1000 Wed May 11 15:18:24.560 BST interface BVI1000 host-routing ipv4 address xxx.xxx.17.49/29 mac-address 0.3030.1 !
Then on PE-B I see the opposite in terms of the ARP:
RP/0/RSP0/CPU0:PE-B#sh arp Wed May 11 15:15:34.789 BST ------------------------------------------------------------------------------- 0/3/CPU0 ------------------------------------------------------------------------------- Address Age Hardware Addr State Type Interface xxx.xxx.17.49 - 0000.3030.0001 Interface ARPA BVI1000 xxx.xxx.17.50 00:00:10 0021.70c6.435a Dynamic ARPA BVI1000
RP/0/RSP0/CPU0:PE-B#show evpn evi mac Wed May 11 15:16:40.858 BST EVI MAC address IP address Nexthop Label ---------- -------------- ---------------------------------------- --------------------------------------- -------- 1000 0015.c546.ffb6 xxx.xxx.17.51 xxx.xxx.175.229 24073 1000 0021.70c6.435a xxx.xxx.17.50 Bundle-Ether1000 24012
Im sure im missing something simple but would be keen to hear from others as to what it is ive missed??
RP/0/RSP0/CPU0:PE-B#sh run int BVI1000 Wed May 11 15:18:58.245 BST interface BVI1000 host-routing ipv4 address xxx.xxx.17.49/29 mac-address 0.3030.1 !
I can see all of the Routes in EVPN and that shows that I can ping from test host xxx.xxx.17.50 to xxx.xxx.17.51 but it seems to be an ARP mapping from the BVI to the MAC's learnt in EVPN.
Any assistance would be gratefully received or if any further info needed can provide.
Richard
05-11-2022 09:01 AM
can you try adding "split-horizon group core" just to see if it makes a difference?
0/RSP0/CPU0:router# configure RP/0/RSP0/CPU0:router(config)# l2vpn RP/0/RSP0/CPU0:router(config-l2vpn)# bridge group irb RP/0/RSP0/CPU0:router(config-l2vpn-bg)# bridge-domain irb1 RP/0/RSP0/CPU0:router(config-l2vpn-bg-bd)# interface bundle-Ether3.1001 RP/0/RSP0/CPU0:router(config-l2vpn-bg-bd-ac)# routed interface BVI100 RP/0/RSP0/CPU0:router(config-l2vpn-bg-bd-bvi)# split-horizon group core RP/0/RSP0/CPU0:router(config-l2vpn-bg-bd-bvi)# evi 10001
thanks
05-11-2022 09:52 AM
Hi @tkarnani
Thanks for the suggestion, just added that and no luck. still no ARP
RP/0/RSP0/CPU0:PE-1#sh arp Wed May 11 17:50:18.991 BST ------------------------------------------------------------------------------- 0/1/CPU0 ------------------------------------------------------------------------------- Address Age Hardware Addr State Type Interface xxx.xxx.17.49 - 0000.3030.0001 Interface ARPA BVI1000 xxx.xxx.17.51 00:00:28 0015.c546.ffb6 Dynamic ARPA BVI1000
l2vpn bridge group CUST-1000 l2vpn bridge group CUST-1000 bridge-domain CUST-1000 l2vpn bridge group CUST-1000 bridge-domain CUST-1000 mac withdraw state-down l2vpn bridge group CUST-1000 bridge-domain CUST-1000 interface Bundle-Ether1000.400 l2vpn bridge group CUST-1000 bridge-domain CUST-1000 routed interface BVI1000 l2vpn bridge group CUST-1000 bridge-domain CUST-1000 routed interface BVI1000 split-horizon group core l2vpn bridge group CUST-1000 bridge-domain CUST-1000 evi 1000
05-11-2022 10:23 AM - edited 05-11-2022 10:33 AM
can we check, i want to verify that the local/remote ESI are the same
show evpn evi vpn-id 1000 mac ipv4 x.x.x.x detail
did you also have this?
evpn evi 1000
evpn evi 1000 bgp
<<<< advertise-mac >>>
thanks
05-12-2022 09:38 AM
Hi @tkarnani
Maybe ive mis-understood but the ESI should be unique to the Datacenter where the hosts are multi-homed. Ive created the diagram to show the setup that im trying to get working:
Here is the output:
RP/0/RSP0/CPU0:PE1#show evpn evi vpn-id 1000 mac ipv4 xxx.xxx.17.50 detail Thu May 12 17:21:05.469 BST EVI MAC address IP address Nexthop Label ---------- -------------- ---------------------------------------- --------------------------------------- -------- 1000 0021.70c6.435a xxx.xxx.17.50 xxx.xxx.115.216 24012 Ethernet Tag : 0 Multi-paths Resolved : True Local Static : No Remote Static : No Local Ethernet Segment : N/A Remote Ethernet Segment : 00aa.aaaa.0333.1122.1000 Local Sequence Number : N/A Remote Sequence Number : 0 Local Encapsulation : N/A Remote Encapsulation : MPLS RP/0/RSP0/CPU0:PE1#show evpn evi vpn-id 1000 mac ipv4 xxx.xxx.17.51 detail Thu May 12 17:21:11.168 BST EVI MAC address IP address Nexthop Label ---------- -------------- ---------------------------------------- --------------------------------------- -------- 1000 0015.c546.ffb6 xxx.xxx.17.51 Bundle-Ether1000.400 24073 Ethernet Tag : 0 Multi-paths Resolved : False Local Static : No Remote Static : No Local Ethernet Segment : 00aa.aaaa.0344.1122.1000 Remote Ethernet Segment : N/A Local Sequence Number : 744 Remote Sequence Number : N/A Local Encapsulation : N/A Remote Encapsulation : N/A
I did try with the advertise-mac command but as per the lab guide here on page 19 it says for anycast GW that the advertise-mac should not be enabled:
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2020/pdf/LTRSPG-2968-LG.pdf
Ive also been doing some further testing and when I shutdown BVI1000 on PE2 everything works and both test laptops can ping each other and all hosts on the wider internet. As soon as I bring up BVI1000 on PE2 things stop working again.
Maybe im missing something but from the docs from what I have read that is the whole point of having anycast gatyeway across multiple DC's.
See what you think of the above and let me know what you think?
Thanks again for you assistance on this one and happy to provide any more debug if required.
Richard
