Highlighted
Beginner
ASR9000 - IPSLA + Tracking
I'm trying to install a static route when an IP address is not reachable, using IPSLA (ICMP echo) + tracking. I've found all the documentation  and know how to configure it, however I'm strugling to configure the IPSLA operation. For some reason it doesn't start, and returns the following message:
RP/0/RSP0/CPU0:A9K-AGR1#sh ipsla statistics 1000
Tue Jul 23 11:25:21.203 WEST
No information available. Specified operation is not configured or operation may have aged out
The configuration is pretty straightforward and I believe it is correct:
ipsla
operation 1000
  type icmp echo
   vrf iub
   source address 10.187.253.137
   destination address 10.187.253.138
   frequency 5
ipsla
schedule operation 1000
  start-time now
  life forever
Could anyone help me find out what am I doing wrong?
Thanks.
Cheers,
Pedro
7 REPLIES 7
Beginner
Highlighted
Beginner
Hi Hu,
I'm aware of the tracking configuration. My issue is with the IPLSA probe that doesn't start.
Thanks.
Cheers,
Pedro
Highlighted
Beginner
Hello Pedro,
There should be a problem with configuration vrf or OID typos, or the XR Version you are running doesnt support SLA.
You can verify the process status for ipsla using admin show proc | in sla
I have tried the above configuration you have - on IOX4.2.3
RP/0/RSP0/CPU0:EQUINOX-A9k#show run ipsla
Mon Jul 29 05:35:31.670 UTC
ipsla
operation 1000
  type icmp echo
   vrf A
   source address 192.168.1.7
   destination address 192.168.1.1
   frequency 5
  start-time now
  life forever
RP/0/RSP0/CPU0:EQUINOX-A9k#show ipsla statistics  1000
Mon Jul 29 05:35:53.130 UTC
Entry number: 1000
    Modification time: 05:30:29.383 UTC Mon Jul 29 2013
    Start time       : 05:30:29.387 UTC Mon Jul 29 2013
    Number of operations attempted: 65
    Number of operations skipped  : 0
    Current seconds left in Life  : Forever
    Operational state of entry    : Active
    Operational frequency(seconds): 5
    Connection loss occurred      : FALSE
    Timeout occurred              : FALSE
    Latest RTT (milliseconds)     : 1
    Latest operation start time   : 05:35:49.593 UTC Mon Jul 29 2013
    Next operation start time     : 05:35:54.593 UTC Mon Jul 29 2013
    Latest operation return code  : OK
    RTT Values:
      RTTAvg  : 1          RTTMin: 1          RTTMax : 1
      NumOfRTT: 1          RTTSum: 1          RTTSum2: 1
It shows no issues.
Thank You
Ahmed Moshref
Highlighted
Beginner
Hi Ahmed,
That's strange, I'm also running 4.2.3. Could you share the SMUs you have installed?
Pedro
Highlighted
Beginner
Check the
disk0:asr9k-mgbl-px-4.2.3
Thank You
Ahmed Moshref
Highlighted
Beginner
Re: ASR9000 - IPSLA + Tracking
Hi Ahmed,
I have that package installed:
RP/0/RSP0/CPU0:ASR-LAB01#sh install active summary
Tue Jul 30 10:34:29.775 WEST
  Active Packages:
    disk0:asr9k-p-4.2.3.CSCud37351-1.0.0
    disk0:asr9k-p-4.2.3.CSCud29892-1.0.0
    disk0:asr9k-mini-p-4.2.3
    disk0:asr9k-doc-p-4.2.3
    disk0:asr9k-p-4.2.3.CSCub22596-1.0.0
    disk0:asr9k-k9sec-p-4.2.3
    disk0:asr9k-p-4.2.3.CSCuc17410-1.0.0
    disk0:asr9k-mpls-p-4.2.3
    disk0:asr9k-mgbl-p-4.2.3
    disk0:asr9k-mcast-p-4.2.3
    disk0:asr9k-p-4.2.3.CSCud07536-1.0.0
    disk0:asr9k-p-4.2.3.CSCub74517-1.0.0
    disk0:asr9k-p-4.2.3.CSCub96985-1.0.0
    disk0:asr9k-p-4.2.3.CSCud54093-1.0.0
I strongly believe that this might be a SMU related issue.
Pedro
Highlighted
Beginner
Hello Pedro,
On my lab , I dont have any SMUs installed- I still suspect the configuration.
Otherwise the only difference is the Card Type , I see yours are Trident cards, however it should be supported unless there is a missing SMU that solves a certain issue on that.
Thank You
Ahmed Moshref
Content for Community-Ad
FusionCharts will render here
