01-15-2013 03:31 AM
Hello.
Trying to establish xconnect between ASR9010 and 7600. xconnect is up and traffic flow, but traffic left from 7600 with 2 dot1Q tags and from ASR without tags (captured with Wireshark).
ASR config:
RP/0/RSP1/CPU0:zip#sh running-config l2vpn
Tue Jan 15 19:25:25.616 UTC
l2vpn
xconnect group xgroup
p2p test1
interface TenGigE0/0/0/0.40
neighbor 10.1.1.2 pw-id 1234
RP/0/RSP1/CPU0:zip#sh running-config interface tenGigE 0/0/0/0.40
Tue Jan 15 19:25:33.604 UTC
interface TenGigE0/0/0/0.40 l2transport
encapsulation dot1q 40
mtu 1514
7600 config:
Router#sh running-config interface g3/1.40
Building configuration...
Current configuration : 106 bytes
interface GigabitEthernet3/1.40
encapsulation dot1Q 40
xconnect 10.1.1.1 1234 encapsulation mpls
end
xconnect status:
ASR
RP/0/RSP1/CPU0:zip#sh l2vpn xconnect detail
Tue Jan 15 19:29:52.892 UTC
Group xgroup, XC test1, state is up; Interworking none
AC: TenGigE0/0/0/0.40, state is up
Type VLAN; Num Ranges: 1
VLAN ranges: [40, 40]
MTU 1500; XC ID 0x40001; interworking none
Statistics:
packets: received 5679, sent 5679
bytes: received 363456, sent 340740
drops: illegal VLAN 0, illegal length 0
PW: neighbor 10.1.1.2, PW ID 1234, state is up ( established )
PW class not set, XC ID 0xc0000001
Encapsulation MPLS, protocol LDP
Source address 10.1.1.1
PW type Ethernet, control word disabled, interworking none
PW backup disable delay 0 sec
Sequencing not set
PW Status TLV in use
MPLS Local Remote
Label 289988 23
Group ID 0x140 0x0
Interface TenGigE0/0/0/0.40 unknown
MTU 1500 1500
Control word disabled disabled
PW type Ethernet Ethernet
VCCV CV type 0x2 0x2
(LSP ping verification) (LSP ping verification)
VCCV CC type 0x6 0x6
(router alert label) (router alert label)
(TTL expiry) (TTL expiry)
Incoming Status (PW Status TLV):
Status code: 0x0 (Up) in Notification message
Outgoing Status (PW Status TLV):
MIB cpwVcIndex: 3221225473
Create time: 15/01/2013 01:03:18 (18:26:34 ago)
Last time status changed: 15/01/2013 14:14:18 (05:15:33 ago)
Statistics:
bytes: received 340740, sent 363456
7600
Router#sh mpls l2transport vc 1234 detail
Local interface: Gi3/1.40 up, line protocol up, Eth VLAN 40 up
Interworking type is Ethernet
Destination address: 10.1.1.1, VC ID: 1234, VC status: up
Output interface: Vl20, imposed label stack {289988}
Preferred path: not configured
Default path: active
Next hop: 10.0.0.1
Create time: 18:25:30, last status change time: 05:16:18
Signaling protocol: LDP, peer 10.1.1.1:0 up
Targeted Hello: 10.1.1.2(LDP Id) -> 10.1.1.1, LDP is UP
Status TLV support (local/remote) : enabled/supported
LDP route watch : enabled
Label/status state machine : established, LruRru
Last local dataplane status rcvd: No fault
Last local SSS circuit status rcvd: No fault
Last local SSS circuit status sent: No fault
Last local LDP TLV status sent: No fault
Last remote LDP TLV status rcvd: No fault
Last remote LDP ADJ status rcvd: No fault
MPLS VC labels: local 23, remote 289988
Group ID: local 0, remote 320
MTU: local 1500, remote 1500
Remote interface description: TenGigE0_0_0_0.40
Sequencing: receive disabled, send disabled
Control Word: Off (configured: autosense)
VC statistics:
transit packet totals: receive 6004, send 6645
transit byte totals: receive 408288, send 425280
transit packet drops: receive 0, seq error 0, send 0
Solved! Go to Solution.
01-16-2013 08:33 AM
Remember that the 7600 does implicit pops, which the asr9000 doesn't do because of the EVC model.
In order for this to work you need to use the rewrite ingress tag pop 1 symmetric under the 9k l2transport interface.
Which may require you to adjust the MTU then also properly to maintain the PW up status.
Both items are discussed in technotes for ASR9000 MTU and ASR9000 flexible vlan model that you can find on the support forums.
regards
xander
Xander Thuijs CCIE #6775
Principal Engineer ASR9000
01-16-2013 08:33 AM
regards
xander
01-16-2013 08:45 PM
Thanks, this work.
I've add "rewrite ingress tag pop 1 symmetric", but forgot to change mtu (and not seen that xconnect went down).
Change mtu and xconnect works.
01-24-2013 03:00 AM
I'm trying this configrations. But I cant access both site. Could you assist please?
interface TenGigE0/0/0/0.211 l2transport
encapsulation dot1q 211
interface TenGigE0/1/0/0.212 l2transport
encapsulation dot1q 212
l2vpn
xconnect group p2p
p2p test1
interface TenGigE0/0/0/0.212
RP/0/RSP0/CPU0:zap#sh l2vpn xconnect brief
Thu Jan 24 12:58:56.160 GMT
Locally Switching
Like-to-Like UP DOWN UNR
EFP 1 0 0
Total 1 0 0
Total 1 0 0
Total: 1 UP, 0 DOWN, 0 UNRESOLVED
01-24-2013 04:49 AM
Umit, if this is the exact configuration you are using I think I see a typo?
the 212 vlan interface is ten 0/ONE/0/0 and in your l2pvn config you used ten 0/ZERO/0/0
xander
01-24-2013 05:09 AM
Thank you xander. I fixed. But still not runing.
I want to connect 2 diffrent vlan on the ASR router. My topology and configrations are below.
Mexico (Cisco VXRG2) --> fiber line Vlan 612 --> LA (ASR9006) --> fiber line Vlan 611 -->Newark (Cisco VXRG1)
First point is Mexico city. I 'm using ( CiscoVXRG2)
interface configs are:
interface GigabitEthernet0/3.612
encapsulation dot1Q 612
ip address 172.17.1.1 255.255.255.252
no cdp enable
end
#ping 172.17.1.2
Sending 5, 100-byte ICMP Echos to 172.17.1.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
LA (ASR9006)
interface TenGigE0/1/0/0.611 l2transport
encapsulation dot1q 611
interface TenGigE0/1/0/0.612 l2transport
encapsulation dot1q 612
l2vpn
xconnect group mex2nw
p2p mex2nwfiber
Newark(VXRG1)
interface GigabitEthernet0/2.611
encapsulation dot1Q 611
ip address 172.17.1.2 255.255.255.252
no cdp enable
end
#ping 172.17.1.1
Sending 5, 100-byte ICMP Echos to 172.17.1.1, timeout is 2 seconds:
RP/0/RSP0/CPU0:zap#sh l2vpn xconnect state up
Thu Jan 24 15:03:48.999 GMT
Legend: ST = State, UP = Up, DN = Down, AD = Admin Down, UR = Unresolved,
SB = Standby, SR = Standby Ready
XConnect Segment 1 Segment 2
Group Name ST Description ST Description ST
mex2nw mex2nwfiber
UP Te0/1/0/0.611 UP Te0/1/0/0.612 UP
RP/0/RSP0/CPU0:zap#sh l2vpn xconnect summary
Thu Jan 24 15:03:36.233 GMT
Number of groups: 1
Number of xconnects: 1
Up: 1 Down: 0 Unresolved: 0
AC-PW: 0 AC-AC: 1 PW-PW: 0 Monitor-Session-PW: 0
Number of Admin Down segments: 0
Number of MP2MP xconnects: 0
Up 0 Down 0
Advertised: 0 Non-Advertised: 0
Number of CE Connections: 0
Backup PW:
Configured : 0
UP : 0
Down : 0
Admin Down : 0
Unresolved : 0
Standby : 0
Standby Ready: 0
Thu Jan 24 15:03:29.766 GMT
Locally Switching
EFP 1 0 0
Total 1 0 0
Total 1 0 0
Message was edited by: Umit AYDINLI Because copy paste errors.
01-24-2013 05:16 AM
your configs and 9k outputs look fine Umit.
considering that you are talking a Gig to a tengig there must be something in the middle and that device may be affecting your forwarding.
eg the switch between the 7200 and the 9k may not know the vlan in its trunk etc.
best way to triage this further is to use the asr9000 packet troubleshooting reference (that you can find under my profile, documents) to get the right commands and see if the 9k is at all seeing them and potentially dropping and for what reason.
but if I were to guess, it may be a switch/trunk issue .
xander
