ASR9000 - xconnect to 7600
Hello.
Trying to establish xconnect between ASR9010 and 7600. xconnect is up and traffic flow, but traffic left from 7600 with 2 dot1Q tags and from ASR without tags (captured with Wireshark).
ASR config:
RP/0/RSP1/CPU0:zip#sh running-config l2vpn
Tue Jan 15 19:25:25.616 UTC
l2vpn
xconnect group xgroup
  p2p test1
   interface TenGigE0/0/0/0.40
   neighbor 10.1.1.2 pw-id 1234
RP/0/RSP1/CPU0:zip#sh running-config interface tenGigE 0/0/0/0.40
Tue Jan 15 19:25:33.604 UTC
interface TenGigE0/0/0/0.40 l2transport
encapsulation dot1q 40
mtu 1514
7600 config:
Router#sh running-config interface g3/1.40
Building configuration...
Current configuration : 106 bytes
interface GigabitEthernet3/1.40
encapsulation dot1Q 40
xconnect 10.1.1.1 1234 encapsulation mpls
end
xconnect status:
ASR
RP/0/RSP1/CPU0:zip#sh l2vpn xconnect detail
Tue Jan 15 19:29:52.892 UTC
Group xgroup, XC test1, state is up; Interworking none
  AC: TenGigE0/0/0/0.40, state is up
    Type VLAN; Num Ranges: 1
    VLAN ranges: [40, 40]
    MTU 1500; XC ID 0x40001; interworking none
    Statistics:
      packets: received 5679, sent 5679
      bytes: received 363456, sent 340740
      drops: illegal VLAN 0, illegal length 0
  PW: neighbor 10.1.1.2, PW ID 1234, state is up ( established )
    PW class not set, XC ID 0xc0000001
    Encapsulation MPLS, protocol LDP
    Source address 10.1.1.1
    PW type Ethernet, control word disabled, interworking none
    PW backup disable delay 0 sec
    Sequencing not set
    PW Status TLV in use
      MPLS         Local                          Remote
      Label        289988                         23
      Group ID     0x140                          0x0
      Interface    TenGigE0/0/0/0.40              unknown
      MTU          1500                           1500
      Control word disabled                       disabled
      PW type      Ethernet                       Ethernet
      VCCV CV type 0x2                            0x2
                   (LSP ping verification)        (LSP ping verification)
      VCCV CC type 0x6                            0x6
                   (router alert label)           (router alert label)
                   (TTL expiry)                   (TTL expiry)
    Incoming Status (PW Status TLV):
      Status code: 0x0 (Up) in Notification message
    Outgoing Status (PW Status TLV):
    MIB cpwVcIndex: 3221225473
    Create time: 15/01/2013 01:03:18 (18:26:34 ago)
    Last time status changed: 15/01/2013 14:14:18 (05:15:33 ago)
    Statistics:
      bytes: received 340740, sent 363456
7600
Router#sh mpls l2transport vc 1234 detail
Local interface: Gi3/1.40 up, line protocol up, Eth VLAN 40 up
  Interworking type is Ethernet
  Destination address: 10.1.1.1, VC ID: 1234, VC status: up
    Output interface: Vl20, imposed label stack {289988}
    Preferred path: not configured
    Default path: active
    Next hop: 10.0.0.1
  Create time: 18:25:30, last status change time: 05:16:18
  Signaling protocol: LDP, peer 10.1.1.1:0 up
    Targeted Hello: 10.1.1.2(LDP Id) -> 10.1.1.1, LDP is UP
    Status TLV support (local/remote)   : enabled/supported
      LDP route watch                   : enabled
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: No fault
      Last local SSS circuit status rcvd: No fault
      Last local SSS circuit status sent: No fault
      Last local  LDP TLV    status sent: No fault
      Last remote LDP TLV    status rcvd: No fault
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 23, remote 289988
    Group ID: local 0, remote 320
    MTU: local 1500, remote 1500
    Remote interface description: TenGigE0_0_0_0.40
  Sequencing: receive disabled, send disabled
  Control Word: Off (configured: autosense)
  VC statistics:
    transit packet totals: receive 6004, send 6645
    transit byte totals:   receive 408288, send 425280
    transit packet drops:  receive 0, seq error 0, send 0
xthuijs
Remember that the 7600 does implicit pops, which the asr9000 doesn't do because of the EVC model.
In order for this to work you need to use the rewrite ingress tag pop 1 symmetric under the 9k l2transport interface.
Which may require you to adjust the MTU then also properly to maintain the PW up status.
Both items are discussed in technotes for ASR9000 MTU and ASR9000 flexible vlan model that you can find on the support forums.
regards
xander
Xander Thuijs CCIE #6775
Principal Engineer ASR9000
6 Replies 6
xthuijs
regards
xander
Thanks, this work.
I've add "rewrite ingress tag pop 1 symmetric", but forgot to change mtu (and not seen that xconnect went down).
Change mtu and xconnect works.
I'm trying this configrations. But I cant access both site. Could you assist please?
interface TenGigE0/0/0/0.211 l2transport
encapsulation dot1q 211
interface TenGigE0/1/0/0.212 l2transport
encapsulation dot1q 212
l2vpn
xconnect group p2p
  p2p test1
   interface TenGigE0/0/0/0.212
RP/0/RSP0/CPU0:zap#sh l2vpn xconnect brief
Thu Jan 24 12:58:56.160 GMT
Locally Switching
  Like-to-Like                        UP       DOWN        UNR
    EFP                                1          0          0
    Total                              1          0          0
  Total                                1          0          0
Total: 1 UP, 0 DOWN, 0 UNRESOLVED
Umit, if this is the exact configuration you are using I think I see a typo?
the 212 vlan interface is ten 0/ONE/0/0 and in your l2pvn config you used ten 0/ZERO/0/0
xander
Thank you xander. I fixed. But still not runing.
I want to connect 2 diffrent vlan on the ASR router. My topology and configrations are below.
Mexico (Cisco VXRG2) --> fiber line Vlan 612 --> LA (ASR9006) --> fiber line Vlan 611 -->Newark (Cisco VXRG1)
First point is Mexico city. I 'm using ( CiscoVXRG2)
interface configs are:
interface GigabitEthernet0/3.612
encapsulation dot1Q 612
ip address 172.17.1.1 255.255.255.252
no cdp enable
end
#ping 172.17.1.2
Sending 5, 100-byte ICMP Echos to 172.17.1.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
LA (ASR9006)
interface TenGigE0/1/0/0.611 l2transport
encapsulation dot1q 611
interface TenGigE0/1/0/0.612 l2transport
encapsulation dot1q 612
l2vpn
xconnect group mex2nw
  p2p mex2nwfiber
Newark(VXRG1)
interface GigabitEthernet0/2.611
encapsulation dot1Q 611
ip address 172.17.1.2 255.255.255.252
no cdp enable
end
#ping 172.17.1.1
Sending 5, 100-byte ICMP Echos to 172.17.1.1, timeout is 2 seconds:
RP/0/RSP0/CPU0:zap#sh l2vpn xconnect state up
Thu Jan 24 15:03:48.999 GMT
Legend: ST = State, UP = Up, DN = Down, AD = Admin Down, UR = Unresolved,
        SB = Standby, SR = Standby Ready
XConnect                   Segment 1                   Segment 2
Group      Name       ST   Description            ST   Description            ST
mex2nw     mex2nwfiber
                      UP   Te0/1/0/0.611          UP   Te0/1/0/0.612          UP
RP/0/RSP0/CPU0:zap#sh l2vpn xconnect summary
Thu Jan 24 15:03:36.233 GMT
Number of groups: 1
Number of xconnects: 1
  Up: 1  Down: 0  Unresolved: 0
  AC-PW: 0  AC-AC: 1  PW-PW: 0 Monitor-Session-PW: 0
Number of Admin Down segments: 0
Number of MP2MP xconnects: 0
  Up 0 Down 0
  Advertised: 0 Non-Advertised: 0
Number of CE Connections: 0
Backup PW:
  Configured   : 0
  UP           : 0
  Down         : 0
  Admin Down   : 0
  Unresolved   : 0
  Standby      : 0
  Standby Ready: 0
Thu Jan 24 15:03:29.766 GMT
Locally Switching
    EFP                                1          0          0
    Total                              1          0          0
  Total                                1          0          0
Message was edited by: Umit AYDINLI Because copy paste errors.
your configs and 9k outputs look fine Umit.
considering that you are talking a Gig to a tengig there must be something in the middle and that device may be affecting your forwarding.
eg the switch between the 7200 and the 9k may not know the vlan in its trunk etc.
best way to triage this further is to use the asr9000 packet troubleshooting reference (that you can find under my profile, documents) to get the right commands and see if the 9k is at all seeing them and potentially dropping and for what reason.
but if I were to guess, it may be a switch/trunk issue .
xander
