06-10-2019 07:55 AM - edited 06-10-2019 08:00 AM
Hello, i'm trying to migrate from BE to pw-he subscriber. Now i have an issue that i do not see dhcp offer from dhcp proxy to client in tcpdump, which i've been collected right next to BNG.
It seems that dhcpd working correctly:
Lease
MAC Address IP Address State Remaining Interface VRF Sublabel
cc2d.e006.0d62 10.253.178.226 OFFER_SENT 58 PE2100.2100 default 0x75
RP/0/RSP0/CPU0:Jun 10 17:59:58.833 MSK: dhcpd[1101]: DHCPD: TP2663: Lease proxy - client<-server lease timer started at 1560178798 for 60 sec lease, 60 secs to expiry
RP/0/RSP0/CPU0:Jun 10 17:59:58.833 MSK: dhcpd[1101]: DHCPD: TP572: L3 packet TX bcast on intf PW-Ether2100.2100 to port 68, source X.X.X.X, vrf 0x60000000 (1610612736), tbl 0xe0000000 (3758096384)
RP/0/RSP0/CPU0:Jun 10 17:59:58.833 MSK: dhcpd[1101]: DHCPD: dhcpd_iox_vlan_processing: configured val of inner-cos is 6
RP/0/RSP0/CPU0:Jun 10 17:59:58.834 MSK: dhcpd[1101]: DHCPD: dhcpd_iox_vlan_processing: cofigured val of outer-cos is 6
RP/0/RSP0/CPU0:Jun 10 17:59:58.834 MSK: dhcpd[1101]: DHCPD: TP2744: Sending packet on VLAN for client cc2d.e006.0d62 on interface PW-Ether2100.2100
RP/0/RSP0/CPU0:Jun 10 17:59:58.834 MSK: dhcpd[1101]: DHCPD: dhcpd_iox_vlan_processing: vlan_id[0] after possible OR with outer-cos: 0xc834
RP/0/RSP0/CPU0:Jun 10 17:59:58.834 MSK: dhcpd[1101]: DHCPD: dhcpd_iox_vlan_processing: vlan_id[1] after possible OR with inner-cos: 0xcffa
RP/0/RSP0/CPU0:Jun 10 17:59:58.834 MSK: dhcpd[1101]: DHCPD: Calling send_pak with pak 0xddc78667
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: ---------- IPv4 DHCPD --- dhcpd_iox_l3_broadcast_packet -------
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: VRF name (id): default (0x60000000)
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: L3 src: X.X.X.X
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: L3 dst: 255.255.255.255
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: L3 dst port: 68
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: L3 input Intf: Bundle-Ether1.801
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: Output Intf: Null
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: FROM: L3
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: NETWORK_ORDER
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: Vlan Info
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: Vlan EtherType 1: 0x0
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: Vlan Priority 1: 0 (0x0)
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: Vlan Format 1: 0 (0x0)
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: Vlan ID 1: 2100 (0x834)
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: Vlan EtherType 2: 0x0
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: Vlan Priority 2: 0 (0x0)
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: Vlan Format 2: 0 (0x0)
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: metadata: Vlan ID 2: 4090 (0xffa)
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: op: BOOTREPLY
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: chaddr: cc2d.e006.0d62
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: xid: 0x034d3c82
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: flags: 0x8000 (broadcast)
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: ciaddr: 0.0.0.0
RP/0/RSP0/CPU0:Jun 10 17:42:32.631 MSK: dhcpd[1101]: DHCPD: pktTx id 93: yiaddr: 10.253.178.226
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: siaddr: 0.0.0.0
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: giaddr: 0.0.0.0
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: cookie: 0x63825363
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: MESSAGE_TYPE: OFFER
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: SERVER_IDENTIFIER: X.X.X.X
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: LEASE_TIME: 300
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: RENEWAL_TIME: 150
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: REBINDING_TIME: 262
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: SUBNET_MASK data: "0xff-ff-80-00"
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: DOMAIN_NAME data: "rt.user.ru"
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: DEFAULT_ROUTER data: "0x0a-fd-80-01"
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: DOMAIN_NAME_SERVER data: "0xd5-f8-00-06-d5-f8-01-06"
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: STATIC_ROUTE data: "0xd5-f8-00-79-0a-fd-80-01"
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: NTP_SERVER data: "0x08-08-08-08-08-08-08-08"
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: VENDOR_SPECIFIC data: "0x01-04-00-00-00-02-02-04-00-00-00-01-ff"
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: RELAY_INFORMATION
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: RELAY_INFORMATION: CIRCUIT_ID: 0x00-04-0f-fa-00-01
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: pktTx id 93: option: RELAY_INFORMATION: REMOTE_ID: 0x01-0e-38-39-2e-32-30-38-2e-31-33-36-2e-31-34-38
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: dhcpd_iox_l3_broadcast_packet Success in send_pak()
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: dhcpd_proxy_os_inc_stat_multi stats ptr not null for vrf 60000000 matches l3intf
RP/0/RSP0/CPU0:Jun 10 17:42:32.632 MSK: dhcpd[1101]: DHCPD: TP2371: Process OFFER for chaddr cc2d.e006.0d62 - successful
mtu 1560
ipv4 unnumbered Loopback1
proxy-arp
arp learning disable
service-policy type control subscriber IPOE-POLICYMAP
encapsulation dot1q 2100 second-dot1q 4090
ipsubscriber ipv4 l2-connected
initiator dhcp
Maybe dhcp proxy doesn't work with pw-he, or there's any bug or something?
it's okay in this scenario:
int PW-Ether2100.2100
mtu 1560
ipv4 address 10.255.255.1 255.255.255.0
ping 10.255.255.100
Mon Jun 10 16:31:00.613 MSK
Sending 5, 100-byte ICMP Echos to 10.255.255.100, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 2/3/6 ms
what i'm missing?
01-26-2021 11:47 PM
unfortunately i did not have service contract for these device.
01-27-2021 07:08 AM
Try to reach to your local Cisco office and ask for an engineer. He can open a TAC service request for you.
