ASR9001 route policy source/destination prefix set questions
Hi All,
We are very new to ASR 9001 XR platform, which we are bit confused route policy source/destination in if statement. We actually raised tech support, and they could not explain properly as well.
say, I have a eBGP session established in between router A, and B. on the router B. i have a prefix-set 1 to control the routes which i want to receive from router A, and i have another prefix-set 2 to control the routes which I want to send to router A.
in normal IOS way, we can either make prefix-list in/out, or use route map.
in XR, I understand that we need create route-policy, and because we want to control both direction routes on router B. we will have to make 23 route policy which for both IN and OUT direction.
Can I please ask in this situation, should we use if statement with source, or destination in prefix-set? or we use both IN/OUT direction policy route with IF statement for destination in prefix-set.
that is the part i am bit confused.
thank you if anyone could clarify with me.
Andy
thecrev
Hey,
I would use 'destination' in the routing policy for route advertisements to router A. That's what works for me. I've never tried using 'source' before.
I wish I could be more helpful on the routes that you want router B to accept from router A, but I usually just use a 'pass' policy for this. I suppose you can try 'destination' and 'source', to see what actually ends up getting populated in router B's table.
Tim.Yu
This is controlled via "in/out" when you attaching the policy on the peer. Below is one of the example:
neighbor 3.3.3.13
remote-as 6000
address-family ipv4 unicast
route-policy Inter_AS_in in
route-policy Inter_AS_out out
next-hop-self
soft-reconfiguration inbound always
Suggest you read this material.
https://supportforums.cisco.com/t5/service-providers-documents/asr9000-xr-understanding-and-using-rpl-route-policy-language/ta-p/3117050
Hi ytpbit,
Yes, i understand it controls by IN/OUT in route policy,
my question was, in the route policy config, we use IF statement follow with 'source' or 'destination' as and then prefix-set to apply certain routes filter.
so, base on the case i post, on both in/out route policy, should i use source, or destination to filter both received and advertised routes?
e.g.
route-policy xyz-advertised-routes-filter
if destination/source in prefix-set-X then
pass
endif
route-policy received-routes-filter
if destination/source in prefix-set-Y then
pass
endif
Andy
This does really confusing.
My understanding is:
Destination is the prefix/route you can see in the routing table
Source is the IP address of neighbour the prefix learnt.
So I suppose you use destination, not source in your case.
I implemented lots of cases of RPL, but seldom meet a case need source so far.
thecrev
Hey,
