How to determine the source of the input drops?
interface Bundle-Ether2
description ISKRA-CORE
mtu 9216
bundle minimum-active links 1
interface TenGigE0/0/0/2
description ISKRA-CORE-BUNDLE-2-1
bundle id 2 mode active
cdp
transceiver permit pid all
interface TenGigE0/0/0/3
description ISKRA-CORE-BUNDLE-2-2
cdp
show interfaces bundle-ether 2
Mon Aug 15 15:25:24.792 MSD
Bundle-Ether2 is up, line protocol is up
Interface state transitions: 23
Hardware is Aggregated Ethernet interface(s), address is f025.72a6.5112
Description: ISKRA-CORE
Internet address is Unknown
MTU 9216 bytes, BW 20000000 Kbit (Max: 20000000 Kbit)
reliability 255/255, txload 48/255, rxload 82/255
Encapsulation ARPA, loopback not set,
ARP type ARPA, ARP timeout 04:00:00
No. of members in this bundle: 2
TenGigE0/0/0/2 Full-duplex 10000Mb/s Active
TenGigE0/0/0/3 Full-duplex 10000Mb/s Active
Last input 00:00:00, output 00:00:00
Last clearing of "show interface" counters 03:04:17
5 minute input rate 6438521000 bits/sec, 840063 packets/sec
5 minute output rate 3839071000 bits/sec, 671273 packets/sec
8862456791 packets input, 8542257864525 bytes, 46144565 total input drops
19006 drops for unrecognized upper-level protocol
Received 1546760 broadcast packets, 1066715008 multicast packets
0 runts, 23 giants, 0 throttles, 0 parity
807 input errors, 631 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
7055446493 packets output, 5076223926722 bytes, 0 total output drops
Output 617340 broadcast packets, 16415285 multicast packets
0 output errors, 0 underruns, 0 applique, 0 resets
0 carrier transitions
show interfaces TenGigE0/0/0/2
Mon Aug 15 15:28:20.805 MSD
TenGigE0/0/0/2 is up, line protocol is up
Interface state transitions: 25
Hardware is TenGigE, address is f025.72a6.5112 (bia 108c.cf17.a5e2)
Layer 1 Transport Mode is LAN
Description: ISKRA-CORE-BUNDLE-2-1
MTU 9216 bytes, BW 10000000 Kbit (Max: 10000000 Kbit)
reliability 250/255, txload 20/255, rxload 83/255
Encapsulation ARPA,
Full-duplex, 10000Mb/s, LR, link type is force-up
output flow control is off, input flow control is off
loopback not set,
Last clearing of "show interface" counters 03:04:16
5 minute input rate 3288038000 bits/sec, 429126 packets/sec
5 minute output rate 786022000 bits/sec, 133124 packets/sec
3596474548 packets input, 3436690262422 bytes, 9914616 total input drops
3 drops for unrecognized upper-level protocol
Received 611691 broadcast packets, 436106754 multicast packets
1 runts, 94 giants, 0 throttles, 0 parity
1790 input errors, 1208 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
1160027585 packets output, 859300872067 bytes, 0 total output drops
Output 259477 broadcast packets, 172558 multicast packets
2 carrier transitions
show interfaces TenGigE0/0/0/3
Mon Aug 15 15:28:34.960 MSD
TenGigE0/0/0/3 is up, line protocol is up
Interface state transitions: 57
Hardware is TenGigE, address is f025.72a6.5112 (bia 108c.cf17.a5e3)
Description: ISKRA-CORE-BUNDLE-2-2
reliability 251/255, txload 78/255, rxload 82/255
Encapsulation ARPA,
loopback not set,
Last clearing of "show interface" counters 02:06:20
5 minute input rate 3224956000 bits/sec, 416334 packets/sec
5 minute output rate 3081579000 bits/sec, 543474 packets/sec
3118867582 packets input, 3035698603580 bytes, 24569671 total input drops
0 drops for unrecognized upper-level protocol
Received 549814 broadcast packets, 360615879 multicast packets
0 runts, 0 giants, 0 throttles, 0 parity
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
3959745159 packets output, 2801126805691 bytes, 0 total output drops
Output 202506 broadcast packets, 11144551 multicast packets
Solved! Go to Solution.
Am i correct assuming you run l2vpn with a bridge-domain (BD) configuration?
RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT - we know the counter shows drops for an ingress unicast VPLS frame that has a source XID that matches its destination XID.
The counter indicates that we are in a flooding mode. In that mode we send the packets to all the NP's that are part of that bridge-domain and we drop the packets on the np that actually originated that one. (packets in the bridge-domain are landing back on the NP that originally received this packet on its enet. So we're dropping this packet as it doesn't need to get forwarded out this NP/interface again.)
for example, bundle-ether 2 gets a packet to unknown destination and hence it floods it to every single interface which is a part of this BD. bundle-ether 2 is part of the BD too, hence fabric sends same packet back to the NP which handles bundle-ether 2. as the source XID would match the destination XID, the packet would get dropped.
Flooding reasons can be found here
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801d0808.shtml
regards,
/A
Look at the following packet troubleshooting guidelines that might help you finding out more about the packet losses.
https://supportforums.cisco.com/docs/DOC-15552
/A
akiritch,
Thanks for the link.
According to the DOC-15552, ASR9K NPs experience following types of drops:
Offset Counter FrameValue Rate (pps)
31 PARSE_INGRESS_DROP_CNT 15435715166 2549
439 RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT 862544686107 101616
565 UIDB_TCAM_MISS_AGG_DROP 15376608187 2549
For easy drop tracking we can clear NP statistics to confirm if these are still increasing counters for our drops using “clear controller np counters all location 0/0/CPU0”.
RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT An ingress unicast VPLS frame that has a source XID that matches its destination XID. These are dropped since it cannot be sent back to the source port.
Reflection filtering happens when the mac look up sees the egress interface would be the same as the ingress interface. So we drop them as those packets are sent to hosts which are already located on the same interface where we get those packets on.
UIDB_TCAM_MISS_AGG_DROP – an interface handling structure does not exist to handle arriving packets. A likely cause for these drops counts is tagged traffic that's sent into the physical port but doesn't match the encapsulation statement of any subinterface. The parent/main interface is an untagged L3 interface, and will reject any tagged traffic that fails classification against any of its subinterfaces/children.
/A
I've just cleared the counters:
Tue Aug 16 17:01:24.958 MSD
counters or files successfully cleared
Tue Aug 16 17:01:27.370 MSD
Node: 0/0/CPU0:
Show global stats counters for NP1, revision v3
Read 20 non-zero NP counters:
22 PARSE_ENET_RECEIVE_CNT 1046948 434238
23 PARSE_FABRIC_RECEIVE_CNT 1678389 696138
24 PARSE_LOOPBACK_RECEIVE_CNT 3684 1528
29 MODIFY_FABRIC_TRANSMIT_CNT 1041955 432167
30 MODIFY_ENET_TRANSMIT_CNT 1419596 588800
31 PARSE_INGRESS_DROP_CNT 4985 2068
34 RESOLVE_EGRESS_DROP_CNT 258725 107310
38 MODIFY_MCAST_FLD_LOOPBACK_CNT 3683 1528
56 PARSE_LC_INJECT_TO_PORT_CNT 1 0
57 PARSE_FAB_INJECT_IPV4_CNT 7 3
69 RESOLVE_INGRESS_IFIB_PUNT_CNT 1 0
74 RESOLVE_LEARN_FROM_NOTIFY_CNT 6 2
170 PUNT_IFIB 1 0
224 PUNT_STATISTICS 9 4
439 RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT 258739 107316
469 RESOLVE_MAC_NOTIFY_CTRL_DROP_CNT 6 2
490 RESOLVE_EGR_LAG_NOT_LOCAL_DROP_CNT 79 33
565 UIDB_TCAM_MISS_AGG_DROP 4982 2066
566 UIDB_TCAM_MISS_PORT0_DROP_FOR_HOST 4982 0
601 PARSE_FAB_MACN_RECEIVE_CNT 6 2
As we can see percentage pps of RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT is huge
I'm trying to find out the source of this kind of drops.
sh ver
Cisco IOS XR Software, Version 4.0.1[Default]
Copyright (c) 2010 by Cisco Systems, Inc.
As an option Upgrade to 4.1.1 is available
regards,
/A
You are correct regarding BD configuration
l2vpn
bridge group 1120
bridge-domain 1120
interface Bundle-Ether1.1120
interface Bundle-Ether2.1120
bridge group 1121
bridge-domain 1121
interface Bundle-Ether1.1121
interface Bundle-Ether2.1121
bridge group 1122
bridge-domain 1122
interface Bundle-Ether1.1122
interface Bundle-Ether2.1122
bridge group 1123
bridge-domain 1123
interface Bundle-Ether1.1123
interface Bundle-Ether2.1123
The source of the input drops is found. This is another side of the bundle-ether 2 link - 7600 port-channel 2 configuration.
I added switchport trunk allowed vlan X,X,X,X,... command to allow vlans that need to be swiched to ASBR (ASR9006) only.
interface Port-channel2
description ASBR
switchport
switchport trunk allowed vlan 86,87,100,143,156,212-214,841,1120-1129,1131
switchport trunk allowed vlan add 1132,1135,1140-1173,1177
switchport mode trunk
switchport nonegotiate
mtu 9216
logging event link-status
mls qos trust cos
no vtp
spanning-tree portfast trunk
spanning-tree bpdufilter enable
end
Good to hear it is solved.
Yes, you are correct, that has been indicted by UIDB_TCAM_MISS_AGG_DROP counter as we’ve found earlier.
There still might be RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT due to unicast flooding, which might OK or not OK, depending on your network topology and traffic flows.
/A
Yes, drops still exsist on NP1 (TenGigE0/0/0/3) for instance
439 RESOLVE_VPLS_REFLECTION_FILTER_DROP_CNT 15547132736 102135
I'm going deeply investigate this later.
Thanks for your help.
