ASR9006/A9K-MPA-4X10GE
we are new on ASR and IOS XR. We have an ASR 9006 with the line card in the discussion subject (A9K-MPA-4X10GE). The four leds on the card are red. Is there any command to activate? Is a Layer 1 problem?
Our release is Cisco IOS XR Software, Version 4.3.0[Default].
Thank You!!!
asad747
Red LEDs mean that Port is physically down at layer-1. Are these ports connected at other end with 10G device??
Can you please share the output of following;
show int desc | i Te
show int te x/x/x/x
Solved!!! I call the other site and it has a 1 GE SFP!!! Damn!!! Thanks!!!
