ASR9006 + DUAL RSP440-TR (Active+Active mode is possible?)
Hello friends. It's my first post here, so forgive me for any misunderstandings. I have some 9006 equipment on my network, with two rsp440-tr (typhoon), one of which is always active and the other in standby. As I use generation 2 cards (2x100GE-TR), I believe that I am restricted by the trougthput capacity of the RSP, but this is a bit confusing for me.
I read in some places (there is little information on the subject), that you can work with this box in two ways: Active/Standby, and active/active, increasing this troughput. My consumption is increasing and I'm looking for some information on the subject, if in fact I can use the box in this way (adding the two rsp440-tr) and if so, how can I do that? Thank you very much!
tkarnani
Slide 22
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2019/pdf/5eU6DfQV/TECSPG-3001.pdf
220G per slot per RSP
if you have 2 RSP 440, you will have 440G per slot.
the fabric is always active, what is active/standby are the protocol processes such as ospf, bgp etc
Thank you
tkarnani
Slide 22
Thank you
You gave me the best news of the day!
