01-06-2015 08:26 AM
hi everyone,I have a question need confirm,could some friends help me.
the topology is like this
both the two ASR9006 use EVC, bvi,between the two ASR9006 run HSRP
1) Does the diagram support or not?why
2)the link between ASR1 and ASR2 can carry hsrp control-plane packet ,keep-alive packet?or not?why
Thank you very much
BR
skype id: zhihuali@live.com
email: zhihuali@live.com
01-08-2015 07:10 AM
It depends a bit on how the OLT connects to both these a9k's. is it with that MS link bonding or is it some sort of switched?
you need to have a l2 link between the 2 9k's to exchange hsrp hellos that is for sure.
the config for that would be a bridge domain with bvi's in each and l2transport interfaces down to the OLT and an l2transport interface between the 2 a9k's.
cheers!
xander
01-08-2015 07:51 PM
Dear Mr.Alexander:
Thanks very much for your kindly help!
About the interface that OLt connect to ASR9k seems like a switched interface.
Could I ask some other questions that are there some production network use similar
topology,I mean use EVC,BVI,HSRP like I asked.
01-15-2015 03:03 PM
yeah you know what it is, for all this stuff there are 2 different standards, that is the EVC model and the IEEE model.
EVC = ethernet virtual circuit (something that the MEF, metro ethernet forum came up with).
the IEEE model is something you are likely most familiar with, it comes with the trunks and all that that IOS classic devices provide.
The a9k, wanting to be MEF compliant followed the EVC model which came with l2transport (sub)interfaces also known as EFP's (ethernet flow points).
Now when we're talking switches, we create an interface VLAN (or SVI = switch virtual interface), on a router the direct equivalent is a BVI (bridge virtual interface)
The good thing about the EVC model is that you create a bridge domain and you can pull in ANY vlan you like and effectively do vlan switching and vlan manipulation, it is way more flexible.
In an IEEE model an interface having a vlan 10 ALWAYS connects to another interface with a VLAN 10, something in the EVC model you don't have as you'll need to connect them together via a bridge-domain.
So EVC is more flexible, but requires more configuration.
In simple "theory" the EVC's bridge domain is the equivalent of a VLAN and you'll need to manually pull in all the EFP's (you know what they are now:) into that BD to link them together, which was something that happens naturally in the IEEE model.
I don't know either why it has to be that complex and full of TLA's (three letter acronyms) :)
hopefully this unraveled some of the complexity and namings...
cheers
xander
