ASR9006 how to upgrade LIC
jinglei yan
I need command line
dpothier
hi Jinglei,
If you upgraded IOS XR sw and now you need to have a license, you can follow the steps on the following link:
http://www.cisco.com/en/US/docs/routers/asr9000/software/asr9k_r4.2/system_management/configuration/guide/b_sysman_cg42asr9k_chapter_0101.html#concept_DD99F4E7E74044A2BC53D256AC372511
The summary steps CLI are:
SUMMARY STEPS
      1.    admin
      2.    show license udi
      3.    http://www.cisco.com/go/license (to get the license)
      4.    Copy the license to your TFTP server.
      5.    admin
      6.    license add license-name [ sdr sdr-name ]
      7.    license license-name location { all | node-id }
      8.    exit
Let us know if that meets your requirements or if you have a different situation.
regards,
David
jinglei yan
Thank you very much,I will try it!
