class-map type control subscriber match-any DSLAM-TEST
match protocol ppp dhcpv6
end-class-map
policy-map type control subscriber DSLAM-TEST
event session-activate match-first
class type control subscriber DSLAM-TEST do-until-failure
1 authenticate aaa list PPPOE-TEST
event session-start match-first
class type control subscriber DSLAM-TEST do-all
1 activate dynamic-template 500
end-policy-map
dynamic-template
type ppp 500
ppp authentication chap pap
ppp ipcp dns 199.180.178.100 216.81.120.100
ppp ipcp mask 255.255.255.255
ppp ipcp peer-address pool CGN
accounting aaa list PPPOE-TEST type session periodic-interval 15
ipv4 verify unicast source reachable-via rx
ipv6 nd other-config-flag
ipv6 nd framed-prefix-pool IPv6_WAN
ipv6 enable
dhcpv6 delegated-prefix-pool IPv6_LAN
pool vrf default ipv4 CGN
address-range 100.73.16.2 100.73.31.254
pool vrf default ipv6 IPv6_LAN
prefix-length 64
network 2607:3200:0:4000::/51
pool vrf default ipv6 IPv6_WAN
prefix-length 64
network 2607:3200:0:2000::/51
pppoe bba-group 31
tag ppp-max-payload minimum 1492 maximum 2000
service selection disable
interface Loopback9
vrf Alma-CGN
ipv4 address 100.73.16.1 255.255.240.0
interface TenGigE0/0/2/3.578
description Test PPPOE
service-policy type control subscriber DSLAM-TEST
pppoe enable bba-group 31
encapsulation dot1q 578
See above for my test configuration. What I am trying to do is set the VSA's in RADIUS for both the unnumbered loopback interface and the VRF. The IPv4 address and IPv6 prefix should be delegated from the local pools. I will post additional troubleshooting output later but in the meantime can someone look at this and verify there isn't something here in the BNG config that would cause the session not to come up? I see authentication passing in RADIUS and it is handing the VSAs back to the BNG but the IP is not allocated in the BNG. Xander?
