12-06-2016 01:25 AM
Hi all
I have a running ASR9K (9006) and another ASR9K (9010) , what am thinking of is to migrate the existing ASR9K 9006 to the ASR9K 9010
They are running RSPs and different LCs , is it possible for me to do it ?
RP/0/RSP0/CPU0:ASR9010#admin show platform
Mon Apr 18 20:10:34.655 AST
Node Type State Config State
0/RSP0/CPU0 A9K-RSP-4G(Active) IOS XR RUN PWR,NSHUT,MON
0/RSP1/CPU0 A9K-RSP-4G(Standby) IOS XR RUN PWR,NSHUT,MON
0/FT0/SP FAN TRAY READY
0/FT1/SP FAN TRAY READY
0/0/CPU0 A9K-2T20GE-B IOS XR RUN PWR,NSHUT,MON
0/4/CPU0 A9K-MOD80-TR IOS XR RUN PWR,NSHUT,MON
0/4/0 A9K-MPA-20X1GE OK PWR,NSHUT,MON
0/4/1 A9K-MPA-2X10GE OK PWR,NSHUT,MON
0/PM0/SP A9K-3KW-AC READY PWR,NSHUT,MON
0/PM1/SP A9K-3KW-AC READY PWR,NSHUT,MON
0/PM3/SP A9K-3KW-AC READY PWR,NSHUT,MON
0/PM4/SP A9K-3KW-AC READY PWR,NSHUT,MON
RP/0/RSP0/CPU0:ASR9006#admin show platform
Mon Apr 18 20:04:53.166 EET
0/RSP0/CPU0 A9K-RSP440-TR(Active) IOS XR RUN PWR,NSHUT,MON
0/RSP1/CPU0 A9K-RSP440-TR(Standby) IOS XR RUN PWR,NSHUT,MON
0/FT0/SP ASR-9006-FAN READY
0/FT1/SP ASR-9006-FAN READY
0/0/CPU0 A9K-MOD80-TR IOS XR RUN PWR,NSHUT,MON
0/0/0 A9K-MPA-4X10GE OK PWR,NSHUT,MON
0/1/CPU0 A9K-SIP-700 IOS XR RUN PWR,NSHUT,MON
0/1/0 SPA-8XOC12-POS OK PWR,NSHUT,MON
0/1/1 SPA-2XOC48POS/RPR OK PWR,NSHUT,MON
0/1/3 SPA-2XOC48POS/RPR OK PWR,NSHUT,MON
0/2/CPU0 A9K-2T20GE-B IOS XR RUN PWR,NSHUT,MON
0/3/CPU0 A9K-MOD160-TR IOS XR RUN PWR,NSHUT,MON
0/3/0 A9K-MPA-2X40GE OK PWR,NSHUT,MON
0/3/1 A9K-MPA-8X10GE OK PWR,NSHUT,MON
0/PM0/0/SP A9K-3KW-AC READY PWR,NSHUT,MON
0/PM0/1/SP A9K-3KW-AC READY PWR,NSHUT,MON
0/PM0/2/SP A9K-3KW-AC READY PWR,NSHUT,MON
Thanks in advance
BR,
Mohammad
12-06-2016 01:48 AM
Yes just migrate the RSPs and the LCs, don't need to do anything else, ensure you have enough power.
12-06-2016 02:32 AM
Thanks Eddie
I have on the 9010 4 power supplies and on the 9006 3 power supplies with the same PID , so am ok to proceed right?
BR,
Mohammad
12-06-2016 02:52 AM
Hi Mohammad,
you can always check that with the Cisco Power Calculator.
Here is the link.
http://cpc.cloudapps.cisco.com/cpc/launch.jsp
12-07-2016 12:21 AM
You can also display the actual power usage on the existing asr9006 and 9010 and compare it with the power budget on ASR9010 to see if it fits in.
Both figures (actual power usage) and (power budget) can be found using cmd: show environment power-supply
Just add up the worst case power used on both routers and compare it with the supply failure capacity on asr9k10
adam
12-07-2016 06:20 AM
Thanks Adam
I have used the power calculator after I replaced the LCs and RSPs between the chassis and the generated reports showed good status , is that enough ?
BR,
Mohammad
12-07-2016 07:53 AM
I’m not sure but I think the power calculator is using max values so if you are good in there then you should be ok in real world.
Might be good to check what values they are using in the calculator though.
adam
