ASR9K H/W Migration
mkhalil10
Hi all
I have a running ASR9K (9006) and another ASR9K (9010) , what am thinking of is to migrate the existing ASR9K 9006 to the ASR9K 9010
They are running RSPs and different LCs , is it possible for me to do it ?
RP/0/RSP0/CPU0:ASR9010#admin show platform
Mon Apr 18 20:10:34.655 AST
Node        Type              State           Config State
0/RSP0/CPU0     A9K-RSP-4G(Active)        IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP-4G(Standby)       IOS XR RUN       PWR,NSHUT,MON
0/FT0/SP        FAN TRAY                  READY
0/FT1/SP        FAN TRAY                  READY
0/0/CPU0        A9K-2T20GE-B              IOS XR RUN       PWR,NSHUT,MON
0/4/CPU0        A9K-MOD80-TR              IOS XR RUN       PWR,NSHUT,MON
0/4/0           A9K-MPA-20X1GE            OK               PWR,NSHUT,MON
0/4/1           A9K-MPA-2X10GE            OK               PWR,NSHUT,MON
0/PM0/SP        A9K-3KW-AC                READY            PWR,NSHUT,MON
0/PM1/SP        A9K-3KW-AC                READY            PWR,NSHUT,MON
0/PM3/SP        A9K-3KW-AC                READY            PWR,NSHUT,MON
0/PM4/SP        A9K-3KW-AC                READY            PWR,NSHUT,MON
RP/0/RSP0/CPU0:ASR9006#admin show platform
Mon Apr 18 20:04:53.166 EET
0/RSP0/CPU0     A9K-RSP440-TR(Active)     IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP440-TR(Standby)    IOS XR RUN       PWR,NSHUT,MON
0/FT0/SP        ASR-9006-FAN              READY
0/FT1/SP        ASR-9006-FAN              READY
0/0/CPU0        A9K-MOD80-TR              IOS XR RUN       PWR,NSHUT,MON
0/0/0           A9K-MPA-4X10GE            OK               PWR,NSHUT,MON
0/1/CPU0        A9K-SIP-700               IOS XR RUN       PWR,NSHUT,MON
0/1/0           SPA-8XOC12-POS            OK               PWR,NSHUT,MON
0/1/1           SPA-2XOC48POS/RPR         OK               PWR,NSHUT,MON
0/1/3           SPA-2XOC48POS/RPR         OK               PWR,NSHUT,MON
0/2/CPU0        A9K-2T20GE-B              IOS XR RUN       PWR,NSHUT,MON
0/3/CPU0        A9K-MOD160-TR             IOS XR RUN       PWR,NSHUT,MON
0/3/0           A9K-MPA-2X40GE            OK               PWR,NSHUT,MON
0/3/1           A9K-MPA-8X10GE            OK               PWR,NSHUT,MON
0/PM0/0/SP      A9K-3KW-AC                READY            PWR,NSHUT,MON
0/PM0/1/SP      A9K-3KW-AC                READY            PWR,NSHUT,MON
0/PM0/2/SP      A9K-3KW-AC                READY            PWR,NSHUT,MON
Thanks in advance
BR,
Mohammad
6 Replies 6
Eddie Chami
Yes just migrate the RSPs and the LCs, don't need to do anything else, ensure you have enough power.
Thanks Eddie
I have on the 9010 4 power supplies and on the 9006 3 power supplies with the same PID , so am ok to proceed right?
BR,
Mohammad
Hi Mohammad,
you can always check that with the Cisco Power Calculator.
Here is the link.
http://cpc.cloudapps.cisco.com/cpc/launch.jsp
You can also display the actual power usage on the existing asr9006 and 9010 and compare it with the power budget on ASR9010 to see if it fits in.
Both figures (actual power usage) and (power budget) can be found using cmd: show environment power-supply
Just add up the worst case power used on both routers and compare it with the supply failure capacity on asr9k10
adam
adam
Thanks Adam
I have used the power calculator after I replaced the LCs and RSPs between the chassis and the generated reports showed good status , is that enough ?
BR,
Mohammad
I’m not sure but I think the power calculator is using max values so if you are good in there then you should be ok in real world.
Might be good to check what values they are using in the calculator though.
adam
adam
